Add effect to frequency range? at DVinfo.net
All Things Audio
Old September 14th, 2006, 06:37 PM   #1
Guest
Posts: n/a
I was wondering if there was a method on either Audition 1.5 or 2.0 that enables you to apply an effect on a range of frequencies. I know some effects let you apply it to a range but is it possible to do it for every effect?
Old September 14th, 2006, 08:16 PM   #2
Absolutely
1. Enter spectral view by "View -> Spectral Frequency Display" or Shift+F
2. Select the marquee tool (second toolbar button on mine) or press M
3. Draw a time-vs-frequency box around the section of audio you wish to work on
4. All edits and effects will be applied to the selection
Good luck!
Sean Schult is offline   Reply With Quote
Old September 15th, 2006, 09:02 AM   #3
Guest
Posts: n/a
Thanks! Much appreciated!
