Thread Tools
Search this Thread
Rode Videomic & alternative mounting angles
I would like to know if the shock mount on the Videomic still works well if it is still mounted on the side, where the mounting base is vertical (mic still pointing forward) instead of horizontal like it would normally be when on top of a camera. I am helping someone decide what equipment to buy and we have not seen or used one of these.
Thank you! |
On the videomic, it's light enough that mounting sideways shouldn't be an issue. On the Stereo Video Mic, it's far too heavy to mount sideways and expect it to hold a balanced position.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#3 | |
I purchased a Rode Videomic today and tested it on my Panasonic DVC30 tonight. I was surprised at the amount of noise it made as it rocked from side to side in it's shock mount. I wasn't holding the camera as still as I would if seriously shooting, and I didn't try it on my tri pod, I walked around a bit. Am I expecting too much or do I need to develop a steadicam type technique!
Al |
#5 |
Are the rubber bands all in place correctly? holding one right now, and it's reasonably solid unless I jar it quite a bit. It could be your technique, but any movement that would jar the mic that much would/should result in unusable video, IMO.
#6 |
Yes, that's true. I wasn't thinking of video content at the time, just testing the mic for movement. When held steady so that the mic doesn't rock at all it should be ok. The bands seem to be fitted correctly. I may go back to the dealer and check it against another unit though. It certainly makes a noise with any slight movement. Thanks.
Al |
#7 |
Sometimes the rubber bands squeek. Give them some silicon lube spray and they'll quiet up. Also, watch for cracking on those bands. They can deteriorate rapidly. RODE will send you a new set for free if you email them.
#8 |
Located the problem. It wasn't adding up! Some of you spoke of squeaks but it was obvious no one else was experiencing this rattle, and after my third test I also knew none of you would find this noise acceptable. It appeared with the slightest movement. I took the mic off the camera and immediately established there was no rattle. Turns out the shoe on my handle is loose. The top screw is so tight I haven't been able to undo it yet, but on the underside there are two screw holes and I'm figuring if I find the right size screws I should be able to tighten up the shoe. Can't remember if they were ever there and came out or have always been missing. When I attach the mic to the camera shoe it doesn't rattle, but I like using the handle. Thanks again.
Al |
