No Audio in After Effects at DVinfo.net
All Things Audio
Old May 22nd, 2006, 06:32 AM   #1
Not sure if this is the right place for this post but here goes anyway.
I have started to experiment with After Effects (6.5) but am pretty sure I am missing something fundamental. The reason is that whatever audio I use in a composition all I get is silence.
I've tried volume level, different audio formats but nada. In the project list of imported files I can preview the audio no problems. It's just when it's part of a composition. Pre-rendered or rendered it's the same deal.
Any ideas appreciated
Dan Burnap is offline   Reply With Quote
Old May 22nd, 2006, 06:53 AM   #2
See if the audio switch is turned on for each layer that has audio. Its all the way to the left of the timeline just to the right of the "eye". You probably won't hear anything until you do a RAM preview.
Jim
Jim Montgomery is offline   Reply With Quote
Old May 22nd, 2006, 07:39 AM   #3
Also, when you "add to render queue" be sure to click on the settings. At the bottom of the very large sub window you will find the audio might be greyed out until you select the export settings.
Jimmy McKenzie is offline   Reply
