I need a pair of mics for live performance recordings - Page 4 at DVinfo.net
All Things Audio
Old May 16th, 2006, 10:57 PM   #46
Originally Posted by Steve House
I've heard of using a pair of selectable pattern large diaphram mics like the Rode NT2-A or large diaphram mics from AT, AKG, Neuman etc like that - in a vertical line with the the capsule ends almost touching each other and both set to cardioid for X-Y or one set to cardioid and the other to figure-8 for M/S..
I heard someone say that the Studio Projects LDS-2 is
quite impressive in M-S. It also does X/Y
and Blumlein. Can be had for under $500.
This is a large-diaphragm mic.
Dave Largent is offline   Reply With Quote
Old May 17th, 2006, 04:03 AM   #47
Originally Posted by David Lach
So would I.
So you think there is nothing to gain in the lower frequencies detail and depth by using a large diaphragm mic? Because that's pretty much the only thing that concerns me, getting good deep bass out of the mics I'll be buying for my stereo setup. I don't want thin sounding mics.
I would also be interested in knowing if using a LD mic as figure 8 and SD mic as the cardioid in an M/S config might be a good way of getting the "best" of both worlds while negating the worst or at the very least, if it's a viable solution when you want to do an M/S config and only have small diaph cardoids and a large diaph figure 8 mic (which in my case could also serve for voice-over purposes).
I don't know - would be an interesting experiment.
One way to avoid a "thin" sound is to use an omni for the mid mic - omnis tend to have a richer sound than do directional mics and while cardioids are usually used for the mid, an omni will work as well.
Old May 17th, 2006, 11:33 AM   #48
Thanks for the tip. I'll take this into account when finally settling for a kit. I guess all that's left for me is to try and hear some mic samples of the ones I'm considering most. I'll feel more comfortable in my decision that way (that's how I chose my MKH416 and I never regreted it).
David Lach is offline   Reply With Quote
Old May 18th, 2006, 06:05 AM   #49
Correction: the model is the LSD-2.
Old July 14th, 2006, 10:04 PM   #50
So much information exchange of experienced people in this thread.
I cannot resist and step in with my 'newbee' question:
Is there any cardioid pair available in the market which could match quality of the AT3031, C4, NT5 and others mentioned here at a similar prize but which does NOT require phantom power?
For me 'ultra porability is of outmost importance and I'd love if I could avoid using a phantom power supply. I'd record directly into my GS400 or an iriver H120 or an Roland R-09 which I am considering to get.
thank you for any sugggestion.
and that stereo bar Steve House mentioned after Dave Largent asked for one, can be seen here:
http://www.taperssection.com/referen..._ShureA27M.pdf
video: NV-GS400 (black jap), Raynox HD-6600 and XL-3000, VW-LDC10 V.light, Velbon C-400, Slik monopod, Hama Hood
audio: SP-CMC8+AT853 cards+omnis / AT822 > DIYpreamp > iRiver iHP120rockboxed, Giant Squid Omnis > iRiver iFP-799
Andreas Griesmayr is offline   Reply With Quote
Old July 14th, 2006, 10:34 PM   #51
Fred Retread
Andreas, you might want to consider the battery operated AT822 stereo microphone for $250. It has a pair of cardioid elements in one housing. This would fit into your requirement for "ultra portability" and eliminate fussing with the set up of two mics.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old July 14th, 2006, 10:44 PM   #52
Andreas, off the top of my head, if you wanted
to use some non-phantom cardioids with a
stereo bar such as that Shure model, I'd
maybe look at the Audio Technica Artist line
for some battery operated mics.
Maybe not as good as 3031 and NT5
but that's about the best I can think
of that don't use phantom.
Maybe someone else would have some
thoughts on this.
Old July 14th, 2006, 10:57 PM   #53
thank's Fred for your fast reply.
edited: and Laurent..your post appeared while I was writing this:
about a weeks ago I bought an AT822! and I really like it - my first 'real' mic!
I want the ability to record audio only as well and therefore just also bought an iriver H120 and had planned to add a socalled Denecke AD-20 preamp+A/D to go optical in on the iriver. Later I got word though that the AD-20 does not sound to good and I also realized that this set up would be quite bulky. Therefore I may change my audio recorder to be an Edirol R-09 - specially if I get confirmed that it's built-in preamp would even be good enough for ambience recording which would make the external preamp obsolete.
Now I do want the ability to record audio to my GS400 and to my audio recorder simultaniously, hence the need of another mic. - preferably one which adds variety to the AT822 and therefore thought of cardidoid or omni pairs, preferably ones which have interchangeable capsules.
In another forum I just got pointed to those:
http://www.soundprofessionals.com/cg.../item/SP-CMC-4
if loud or quiet sound coupled with:
http://www.soundprofessionals.com/cg...item/SP-SPSB-6
seems like a quite good solution! Those mics house AT853 cardioid capsules, if I understand right the capsules are changeable to house omnis as well. They seem to perform alright even with plug in power and if powered do with just 9 Volt.
Is this something like you, Dave, were pointing at?
I also wonder if, in case I get the Edirol R-09, the onboard mics could even be sufficient.
( I am buying too much stuff lately...)
Old July 15th, 2006, 06:12 AM   #54
I...
Not necessarily. You could send audio from one set of mics to both the camera and the audio recorder with by using an inexpensive mixer or mic splitter with multiple outputs.
Old July 15th, 2006, 07:54 PM   #55
Sorry, I havent had time to read all the posts,
but I use Shure SM81's. 1 far left, 1 far right, and a set in the XY setup in the middle. It covers nicely, prefrb. not more than 10 feet away from the stage, unless it's run through a sound reinforcement system. If it is, I try to get an output from the sound tech, if not mic the speaker cabs with a dynamic (Shure SM57 and AKG D12) mics. I tend not to put a condensor on a speaker cab, it comes in too hot.
For high end stuff, I use Neumann KM140's (cardioid head), on the same pattern, and the Crown Stereo PZM (MKII?) mic in the middle behind the XY pattern.
Daniel Wang is offline   Reply With Quote
Old July 16th, 2006, 01:43 AM   #56
Originally Posted by Douglas Spotted Eagle
WAVES has 4-5 plugs that dematrix M/S if you would prefer it in FCP or Soundtrack Pro.
What do you think of those plug-ins
that are supposed to turn your
XY recordings into M-S? There's
got to be something here that is
not the same as M-S? There's got to
be some compromise?
Old July 16th, 2006, 02:25 AM   #57
obviously!...though not for me, I had never thought of this...
I am planning to document a 10 day long art and music festival in south India. I won't have any help and will do all myself. I thought to set up a separate audio recorder, and shoot videos + AT822 but not only from a tripod, but also at times to carry the cam to get other angles, close ups etc. I want to put all on a DVD which features audios of individual musical performances at 'full length', but videos which rather show the variety of musicians then covering full lenght individual performances. I guess in this case a separate recorder still would be good.
you say: 'inexpensive mixer or mic splitter'...that makes me very curious though...could you please point at one specifically, e.g. brand name, model name..?
thank you ( - and please tell me if my postings disturb in this thread and I rather stopped posting here )
Old July 16th, 2006, 05:36 AM   #58
There are a number of ways to split a single mic signal for two destinations. Here's a couple of examples of simple splitters, The Whirlwind Splitter-L
http://www.whirlwindusa.com/split.html#splitterl
and the SP1X2 and SP1X3 right below it on that page. For stereo micing you'd obviously need 2 of them, one for each mic line. HOWEVER, in my previous post I overlooked the fact that you were using the the AT822 and I'm pretty sure these won't work with it. They are designed to split a mono, balanced mic to feed 2 or 3 inputs. But your AT822, while it does use an XLR output, is wired so it sends two unbalanced stereo channels on the XLR and a splitter designed for balanced mono will do very strange things to the signal even though the connectors are compatible- very likely you'd hear nothing at all on the outputs.
You said you wanted to record the audio continuously and move around with the camera catching different angles etc. For good music recording the mic needs to be fairly precisely positioned and should stay in that one place. As I think about your project, I'd use the 822 on a stand to feed your recorder that becoimes the program's audio and the in-camera mic to record a "scratch track" with the video to aid you in lining up the two in post. The quality of the audio in camera is immaterial in that case since you just using it for reference and it won't appear on the finished product.
I'm a little confused though. Are you planning on using the 822 or in a previous post you also mentioned you were looking for a pair of seperate cardioids. Is this an either one or the other or are you planning on going with both?
If you're by yourself, what are you doing about security for your stuff as you move about the crowd? Call me distrustful but I don't think a pocket-sized $400 recorder and $250 mic are going to last 2 minutes in a crowd if you move away from them to get a closeup of the performers.
Your posts are just fine, keep 'em coming - we're all just users helping users. If you have a question that you think might go too far off-topic in a particular thread, just post it as a new thread.
Old July 16th, 2006, 06:44 AM   #59
....But your AT822, while it does use an XLR output, is wired so it sends two unbalanced stereo channels on the XLR and a splitter designed for balanced mono will do very strange things to the signal even though the connectors are compatible- very likely you'd hear nothing at all on the outputs.
interesting...I believe that I will not need a splitter anyway though. I am even happy that the AT822 does not have ballanced cables, because little volume, little weight, easy to set up are essential to me.
Yes, I was planning to set up the audio recorder fixed with it's mic near to the sound source. Why I was thinking to get another mic, or rather a pair of cardioids or omnis ( best interchangeable ), is that I thought I wanted to have decent sound from both the cam and the audio recorder, the AT822 using shockmounted on the cam. But you are very right, I could just drop wanting to have 'useable' audio from the cam, only use it's onbopard mic's sound as reverence.
No, I don't worry. At the festival I am thinking of I would not have any security concern. I believe that the audio recorder would be way up in front at the front edge of the stage for everybody to see, nobody would touch it. Very likely I'd even get help like electrical current set up ( besides: India does have some inexpliable sides: e.g roadside shops in Mumbay just wrap their goods for the night with some plastic cover, and there will be many poor homeless sleeping next to it without touching it )
thanks
Old July 16th, 2006, 10:29 AM   #60
Fred Retread
be some compromise?
Interesting question to ponder. I come up with "yes, there is a compromise."
Short form explanation:
The M-S works with three polar patterns, the XY with two. Over the coverage range of 180° in front, the XY pair has about 3/4 of each of two lobes in the field, for a total of 1 1/2 lobes. The M-S has one lobe to the front and two half-lobes to the sides for a total of 2 lobes. Without doing actual computations, my sense is that there will be more sounds more off-axis with the XY than with the M-S, with resultantly more coloration.
Long form explanation:
Placed at the same point in the room, both M-S and XY arrays are subjected to the same sound pressure information. In post, the mid and side signals from the M-S array can be mixed to form left and right channels, where L = M + S and R = M - S. And in post, the left and right channels from the XY array can be separated into mid and side signals. M = L/2 + R/2, S = L/2 - R/2.
[Side Note: This simple math is not a trick or an approximation invented by audio engineers, it's solid math and physics and has many parallels in the physical world. Any quantity with magnitude and direction is indistinguishable from the correct pair of perpendicular components added together. For instance, a crate on a floor being pulled by a rope to the northeast is the same as the crate being pulled with two ropes, equally to the north and east. And a million ropes pulling on that crate in a million different directions with a million different amounts of force would have the same net effect as one rope pulling in one direction. And finally, that one rope's force could be broken down into two perpendicular components. Such is is that all the frequencies and amplitudes of all the sounds in a room at a point can be represented by variations in pressure coming from the front plus variations in pressure coming from the side. Don'tcha love it?]
So yeah, the XY pair is, in a perfectly real sense, also recording the mid and side signals in both channels, and they can be retrieved later.
The question then becomes, does any given XY pair record the same mid and side signals as any given M-S pair? For any real comparison of particlar makes and models it's easy to see that the answer is no. There would be differences in the frequency responses of the elements and all that.
But let's rule those out and say that we have built arrays with identical cardioid component elements; two elements for the XY and three elements for the M-S. We know that we get off-axis coloration with cardioids. Let's say we have a musical sound coming from the front right. In my estimation there would more off-axis coloration with the XY than with the M-S. That's because for the M-S array, the sound source is 45° from the front and from the right side. The third element of the M-S is going to contribute very little signal to the mix. But for the XYs at 110° separation from each other, the sound source is 100° from the left facing mic and only 10° from the right facing one. Cardioids are irregular shapes so when all this is added up to mid and side signals, they would be different for the two arrays.
Which one will sound better? Hell, I don't know. [Edit-- But my guess is, other things being equal, that the M-S would sound better. All that said, I think I'll stick with ORTF :>) ]
