One last Rode question... at DVinfo.net
All Things Audio
Old April 1st, 2006, 02:55 PM   #1
Looks like I've decided on the NT1 or NT2 from all I have read here. Just one last question on the differences in the two. I know the NT2 is a little longer in size, but do they function and sound the same? What are the differences in the two?
BTW, I have purchased for NT3 for indoor work and wanting one of the two above for outdoors.
Thanks again.......JD
John Dombrowski is offline   Reply With Quote
Old April 1st, 2006, 04:57 PM   #2
The NT1 requires external phantom power while the NT2 can run on either an internal battery or on phantom. The extra length of the NT2 is due to the space for the battery. Other than that they are the same mic.
Old April 1st, 2006, 07:49 PM   #3
What exactly is phantom power as opposed to phantom/battery power and which one is preferred?
Old April 1st, 2006, 09:43 PM   #4
Phantom power is power supplied down the mic cable from your mixer, input device, or some camcorders. It is usually preferable to battery power as it is constant, and most mic's degrade as the battery dies. Sometimes you'll see mics rated on battery and phantom power separately.
When you can use phantom, use it. When you can't, batteries are there.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 4th, 2006, 09:55 AM   #5
incorrect model numbers maybe?
I use a Rode NT2 studio mic for voice overs, it requires phantom power and there is no place for a battery. The NT1 (current version I think is NT1a) has no switches, the NT2 I have, has a switchable 10db pad, and can go cardiod or omni. The newer version of that is the NT2a, which has even more variable settings.
http://www.rode.com.au/?pagename=Products&product=NT2-A
Bill Mecca is offline   Reply With Quote
Old April 4th, 2006, 01:49 PM   #6
Bill, I think they've been talking about the Rode NTG1 and NTG2. They're both shotgun mics designed for video. I do understand your confusion because the NT2 and NT1 are both large diaphram condensers. Hope that clears some things up.
Matt Ludwig
MSL Productions - www.freewebs.com/mslpro
Matt Ludwig is offline   Reply With Quote
Old April 4th, 2006, 04:22 PM   #7
Yep, left out the "G"s. My bad.
Old September 26th, 2006, 07:26 PM   #8
I'm going to hiijack this post for my question as I've read tons of post I've searched here, but I'm no expert and am lost in "cardiodic, hyper, omni..." stuff.
I need a mic to take guests' interviews on a wedding. There will be lots of people changing fast so no lav mic.
Guests will be holding the mic themselves, whichwill be made wireless with the Senn G2 with plug-on transmitter.
Will Rode NT3 be good for the job?
If not, what will do the job in the that price range?
Canon 5D2 & 7D, Canon XH-A1, Senn. G2, Steadicam Merlin, Glidetrack, Sony D-50, Edius 5
Marko Urbic is offline   Reply With Quote
Old September 26th, 2006, 07:36 PM   #9
Definately not NT3.
Dave Largent is offline   Reply With Quote
Old September 27th, 2006, 01:02 AM   #10
Marko--
You'll probably want a dynamic mic for handheld use. You should probably be able to get a fairly decent one for less $$$ than you'd spend on a condenser.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline   Reply With Quote
Old September 27th, 2006, 02:45 AM   #11
So I'm not on the right track, glad I asked. :)
Thanks for the tip.
Old September 27th, 2006, 04:37 AM   #12
I'll second Jorod's recommendation of a hand-held dynamic mic. Electrovoice and Shure both have several "reporter's mics" that would work very weel in this situation. Condenser mics usually require a delicate hand to minimize handling noises, something that's going to be a problem with the mic being put in the hands of "civilians." Dynamic mics are inherently a bit less sensitive to handling and those designed for ENG use often have internal shock-mounts and pop-filters for the capsule to further help silence noise.
The omni, cardioid, hyper.. "thing" relates to the pickup pattern of the mic ... Omni being a sphere, cardioid being a pushed-in hemisphere heart-shaped in cross section. hypercardioid being more like a tear drop with the pointy-end pushed in, etc. A visit to the downloadable documentation section on the Shure website or a scan of Wikipedia can turn up detailed explanations with pictures.
Old September 27th, 2006, 04:56 AM   #13
Thanks for the detailed info.
Much appreciated!
