#16 | |
As to recording - the Double M/S requires at least 3 channels - the front mid mic, the side mic, and the rear mid mic. That means, of course, simultaneously recording at least 3 tracks if you're going to decode them in post. While you can do it by using 32kHz 12 bit audio in the XL2, using that low resolution means a much lower recording quality and I doubt it could be recommended. A better bet would be a mutli-track recorder that would be suitable for double-system sound. One example would be a Sound Devices 744t which would give you an outstanding recorder with top quality audio, that can sync to the video clock, produces bwf files, and incorporates timecode.
Good news, Cousins! This week's chocolate ration is 15 grams! |
#17 |
Surround Sound Recording
Thanks Steve,
I looked at the site and think that the simple IRT cross using four cardiods for ambient sound might be the best way for me to go. Now I have to find a relativley inexpensive 4 channel field recorder to go into. Unfortunatley the 744T is way to costly for me. Michael Hamilton |
#18 |
Take a look at the Edirol R-4. Good (not best) performance, 4 mic preamps with phantom hard drive recorder. I think street price is about $1600.
Boy there's been a lot of talk in this thread about the (obvious? assumed? proven?) desirability of quad or 5.1 recording in the field. Anybody actually heard playback on these recordings? Is there demonstrated benefit? Is this what all the hot hollywood sound recordists are doing? Just askin'. (I'm not questioning 5.1-7.1 mixing and playback, just acquisition. What I hear in theaters is efx, not room tone, in rear and side channels. But maybe I'm not going to the right movies.) |
#19 | |
There was a company at the AES NY show last fall showing surround capture and repro with a magic box and a handfull of Schoeps. Try reaching out to redding audio in CT to see if they can hook you up with the company. Regards, Ty Ford |
#20 |
Hello again all.
Sorry - I have been a bad boy for not following up on this thread that I started! I have given up on the Sony mics (finally) - I had an event come up and I needed mics urgently so I contacted Sennheiser and eventually settled on 4 x e935's and 2 x e945's (Evolution Series). I used these mics at the last event (along with Sony UWP-C3's, Alesis FireWire Mixer, and Crest Audio PA's) and got what I feel to be fantastic results. Steve - I did have a very strange issue that I managed to solve in post (the synchronizaton of the audio and video from different sources) and I just noticed that you mention the Sound Devices 744t... 'that can sync to the video clock'. Does this mean that, for example, a Sony VX2100E or Sony FX1E has a 'video clock' (or any other camcorder for that matter)? That might sound like a really strange or stupid question but does this mean that if I were to daisy chain the FX1E, the VX2100E, and the Alesis Mixer (all FireWire devices) that I could choose which 'Master Clock' to use (the Alesis software does have a selection for this but the mixer is the only option that is available to choose although I have never plugged in the cameras at the same time - read too much about blowing FireWire ports)? Regards, Dale. Last edited by Douglas Spotted Eagle; April 13th, 2006 at 07:20 AM. Reason: rumors are not permitted on DVInfo.net |
#21 | |
The advantage of using an MS technique for 5.1 front is that the "mid" mic by itself is your front-centre channel. Whether you're shooting conventional stereo or surround, remember too that a large percentage of your audience will be viewing you program with mono sound (or it might as well be mono because of the crappy TVs they have - 2 4-inch speakers separated by 10-12 inches) so unless you're shooting for theatrical release you need to keep that in mind. Non-coincident mic placements, such as the IRT Cross, can give all sorts of phasing problems when downmixed to mono.
#22 | |
I misspoke when I said the SD recorders could sync to incoming video. Checking the manuials, their TC clocks will sync to incoming timecode and their sample clocks can sync to incoming Word Clock or extract clock from incoming digital audio on the AES or SP/DIF inputs and sync to it. BUT AFAIK, you can't plug a video signal into any of their inputs and have 'em sync up. There are products such as the MOTU Digital Timepiece that can extract word clock from various sources, including video and timecode, and you could do it that way if you needed to [camera video out] --> [Timepiece] --> [SD Recorder WordClock In]. But for maintaining sync between picture and sound it's not necessary. Definitely "daisy chaining" the firewire ports of the camera and mixer won't won't provide clock sync. What was the "strange issue" you encountered? S
#23 |
Steve - thanks for the great explanation - much appreciated.
The 'strange issue' to which I refer is detailed in the following thread: http://www.dvinfo.net/conf/showthread.php?t=64559 In other words - given the exact same sample rate/bit depth - one hour of video/audio captured from the camera via firewire should have been exactly equal to one hour of audio captured via firewire from the mixer. This was not the case and although there are explanations in the thread detailed above I find that I am still searching for answers. Regards, Dale. |
#24 |
field surround aquisition
Seth,
Thanks, I found that recorder. I might get it. Michael Hamilton |
#25 |
Steve,
I just would like my audience to have a more complete feeling of being in the environment that is shown on the screen. Also, has anybody tried surround using two ms mics facing 180 degreees in opposite directions front to back? Michael Hamilton |
#26 | |
