Monster Cables... at DVinfo.net
All Things Audio
Old February 23rd, 2006, 01:09 AM   #1
Monster Cables...
Has anyone ever used monster cables...
Is it all hype or are they worth every penny??
link:
http://tinyurl.com/ht8se
Dante Waters is offline   Reply With Quote
Old February 23rd, 2006, 01:20 AM   #2
I've used them and they're good, but not better than regular professional grade cables which are a lot cheaper - if Monsters were better, you'd see them being used by everyone and that's not the case.
Andrew Khalil is offline   Reply With Quote
Old February 23rd, 2006, 01:42 AM   #3
Which brand are you referring to?
Old February 23rd, 2006, 02:00 AM   #4
No brand in particular, but say Canaire or Hosa or other brands marketed to the pro market which are much more reasonable priced and can be bought at custom lengths.
Old February 23rd, 2006, 02:14 AM   #5
I like Monster Cables. I have a couple of the THX series cables that are awesome. I also picked up a couple of Monster speaker terminals from Radio Shack. I was happy to see that the Shack was not just selling low quality products. I also like Canare cable. I make a lot of my own cable out of it. Their 'quad' comes in multiple colors and is the best quality cable I have seen.
Glenn Davidson is offline   Reply With Quote
Old February 23rd, 2006, 03:17 AM   #6
Some hard data and good commentary:
http://sound.westhost.com/cables.htm
They probably cost pennies to make. The rest is markup.
Perhaps I'm exaggerating a little, but almost all of the cost is retail markup.
Old February 23rd, 2006, 05:51 AM   #7
Wire is wire is wire. Monster makes good quality cables but all the hype about them being special is just that - hype and as others have said professional grade cables from other manufacturers are available at a fraction of the price that are just as good. I wouldn't use super cheap stuff from your grocery store's hardware section but that's because the real cheap blister pac stuff are made with cheap metal in the connectors so they lose their springiness resulting in intermittent connections and poor quality control on the assembly leading to things like cold solder joints etc. Cheap shielded cable used for audio interconnects and video cables may have inadequate shielding, that sort of thing. But manufacturers like Canare and Belden make cable that's perfectly fine.
To the best of my knowledge no one in a truly blind test has ever been able to hear any difference between, for example, expensive Monster cable speaker cable and plain old hardware store 14-gauge zip cord. A strand of copper is a strand of copper.
Old February 23rd, 2006, 06:55 AM   #8
I wouldn't go *that* far. Monster and cable companies like that mostly sell snake oil, no doubt. But...get good cable, cable rated for the job. High end Belden, Mogami, Canare are all good choices. If you're mobile, don't get the quad-strand cables, as the copper is so thin even though it's braided into quad conductors, it breaks down very quickly. You're better off with heavier 2 conducter than thinner 3 conducter cable.
Also, various kinds of copper are not made for audio; the resistance is higher. But, it's not enough to worry about if you've got cables from within the music or audio industry. It's the guys that make their own cables out of lamp cord or antenna wire that need to worry. :-)
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 23rd, 2006, 08:05 AM   #9
Funny anecdote: I never buy those overpriced cables either, but I needed a set of component video cables a couple years ago and decided it'd spring for some of the expensive ones. Less than a year later I had a video problem and traced it down to a failure in one of the component cables. Now these had just been sitting there, connected between my DVD recorder and LCD screen ever since I bought them. All my cheapo cables were still working fine. So this convinced me not to waste money on the high priced stuff in the future.
Old February 23rd, 2006, 08:51 AM   #10
strenght
All good points... can't seem to find the following at b&h:
headphone connector (miniplug I believe)
to rca/phono
Also coax-al to rca dvd player to an old TV
I know this last one probably doesn't exist but DVI to coax-al, trying to connect my tv to this editing system (powerbook/fcp)
Old February 23rd, 2006, 08:53 AM   #11
strength
Well to tell you guys the truth I was asking if the shielding was any better than what others sell... because I notice how quickly some of my wires break and I get shorts when I want to record something.
out of these:
http://tinyurl.com/km4tl
Which would you choose?
I need to record sometimes from a sound system, or even play back to a sound system...
Old February 23rd, 2006, 09:10 AM   #12
I have one point to add to this. Just a couple of weeks ago, I upgraded my DirecTV from a standard Tivo, to an HD Tivo. The service man who came to do the installation, was the owner of the company.
After mounting the new dish, he came in to hook up the Tivo, and the first thing he did was disconnect the Monster component, and Monster HDMI cables I was using, and he replaced them with a lighter less expensive.
The reason he gave made perfect sense to me. He said that the quality of the picture etc. is no different and that he has seen many units damaged or destroyed by the use of the big Monster cables. Why, because the cables are too stiff and tend to damage the recepticals on the VCRs, DVD players, TIVOs, and TVs, etc.. And, this is from a professional who sells and installs all types of video and stereo equipment for a living, 6 days a week.
I now have a couple of great cables sitting in a box, the HDMI cable alone was $100.00 at Circut City.
I hope that gives everyone some food for thought.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old February 23rd, 2006, 09:20 AM   #13
That's very true also! The few times I have used the more expensive cables, I was concerned about the amount of strain being placed on the fragile female RCA connectors. I stopped using a heavy s-video cable on my video cameras because of this.
Old February 23rd, 2006, 09:27 AM   #14
Funny because I'm looking at that now:
http://tinyurl.com/o6dc9
but I want to go from the computer to this older tv with the screw in connector I think it's coax-al or bnc, so I was looking at this cable too:
http://tinyurl.com/rserx
Old February 23rd, 2006, 09:30 AM   #15
Of course we're happy when people buy from our sponsors, but in this case being able to touch and hold the actual cables might sway your decision one way or another. Have you looked at cables in any local stores?
