anyone see a problem with this? at DVinfo.net
All Things Audio
Old February 9th, 2006, 04:20 AM   #1
Rode NTG2 with shock mount on boom
Xlr balanced cable to 3.5mm/ 2.5mm mini jack adapter
Edirol r1
The reason I ask is because Th eEdirol does not have balanced line/mic in. The Edirol Guys at video forum assure me that this will be okay just wanted to double check before purchase.
Regrds Greg C
Greg Corke is offline   Reply With Quote
Old February 9th, 2006, 04:04 PM   #2
Fred Retread
As long as you accept that the XLR cable will not be balanced in that configuration.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old February 9th, 2006, 04:39 PM   #3
Thanks Fred,
I thought that but the guy at Edirol was tryinging to tell me it was but that wasn't what I had been led to believe posting on the subject here.
Thanks Again Greg C
Old February 9th, 2006, 09:48 PM   #4
Sponsor: VASST
Here is another option for you. For about the same price as the Edirol R1 you can get a Marantz PMD660 and have XLR inputs with phantom power. I just bought one back in December and I’ve been very happy with it. It records 48K/16-bit just like DV audio. I’m using it with an AT897 shotgun on a boom.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old February 10th, 2006, 03:36 PM   #5
Fred Retread
Greg, if you used this transformer-based adapter you could have a balanced cable run and a mini plug for the Edirol:
http://www.bhphotovideo.com/bnh/cont...ughType=search
Of course, If your run is less than 25 feet or so, an unbalanced run is not likely to be a problem.
Old February 10th, 2006, 05:19 PM   #6
Edirol r1
Regrds Greg C
John mentioned the Marantz as an option to look at before purchasing the Edirol. You might also want to look at the new TASCAM recorder with timecode.
Old February 11th, 2006, 06:19 AM   #7
Thanks Guys
As usual some really helpful info I'm gonna check it all out now.
Regards Greg C
