#46 |
M/S micing can be achieved by using separate Mid and Side mics or with some mics aready configured for M/S that have both capsules in one body.
Neumann RSM 191 (gorgeous sounding but pricey) The Sennheiser 418s Sanken CSS-5 AT 835ST (I think).....come to mind. If you have a mixer like the Sound Devices 442, you can record in M/S but monitor in regular stereo because it has a built in matrix for the headphones. It also has another matrix so you can convert M/S mics to s regular stereo output. Regards, Ty Ford |
#47 |
so can we say that: without a mixer we can not use MS mics ? because it has two 3pin xlr output. when I want to plug to camera xlr inputs I need to switch any of two, not both at tha same time, or cameras (such as XL2) does sound mix among the two inputs ?
am I right ? regards alkim. |
#48 |
Well you can record MS directly to the camera, one mic per channnel, but then you'll have to dematrix them in post.
And monitoring will be weird unless your mixer will dematrix the M/S. Regards, Ty Ford |
#49 | |
Good news, Cousins! This week's chocolate ration is 15 grams! |
#50 |
I talk about one cardoit and ona figure-8 together, and two 3 pin XLR output, pne is for cardoit and other is for figure-8. so will I plug these two outputs to two inputs? such as XL2 has two inputs. camera record seperate channels, and then I dematrix in post ? but without a micer How I monitor on XL2 camera. is there any option switching any source for monitoring ?
another question: many MS mics has two 3pin or one XLR-5M outputs, such as AT815ST, Neumann RSM 191 etc. each of these outputs represent one element ? if so, if I plug only cardoit element to the camera, MS mic behaves like mono shutgun ? thanks, alkim. |
#51 |
[QUOTE=Alkim Un]I talk about one cardoit and ona figure-8 together, and two 3 pin XLR output, pne is for cardoit and other is for figure-8. so will I plug these two outputs to two inputs? such as XL2 has two inputs. camera record seperate channels, and then I dematrix in post ? but without a micer How I monitor on XL2 camera. is there any option switching any source for monitoring ?
**You monitor though the headphone jack as always, but it will sound weird. Rely mostly on the M channel and keep good levels. another question: many MS mics has two 3pin or one XLR-5M outputs, such as AT815ST, Neumann RSM 191 etc. each of these outputs represent one element ? if so, if I plug only cardoit element to the camera, MS mic behaves like mono shutgun ? **Pretty much. The AT 835ST is shorter and better than the AT815ST and both have a switch that lets you choose mono shotgun or XY stereo or MS. Please visit the online archives on my website for my review of the mic. Ty Ford |
#52 |
I finally got a MKH 418S MS and found that I could monitor the M channel on my XL2 by pulling the headphone jack half way out of the plug.
I bring the DV signal into FCP just like any other, and wind up with a left and right stereo channel, M on one channel and S on the other. Then I duplicate the S channel, and place the dup on a third track in the timeline. I pan the S channels in opposite directions, and make sure the M channel is centered. It sounds great, but I'm not sure if I'm doing it right. It seems as if there should be more stereo spread but I guess thats what a single M/S mic gives you. When I bring down the two side channels I get a very strong and clean middle channel. I can stand about six feet away from the mic in a noisy environment, talking at a normal level and it sounds almost as good as a lavalier. There is a draw-back though. Does anybody know of a 7-3pin XLR converter that I can use to hook up to a plug-on transmitter? As far as I know, If you just want to go hand-held with a reporter there is know way make this mic wireless. Michael |
#53 |
Sounds like you left out one step in your NLE. After you have duplicated the S track, invert the phase on the duplicate. The exact mix is L=M+(+S) and R=M+(-S) (Assuming that when you recorded, the "front" of the figure-8 side mic was pointed stage left.)
Good news, Cousins! This week's chocolate ration is 15 grams! Last edited by Steve House; July 29th, 2006 at 03:54 AM. |
#54 |
persactiplopoly!
Ty Ford |
