All Things Audio -- topics from 2002 thru 2004 - Page 7 at DVinfo.net
All Things Audio
Old June 24th, 2003, 09:16 PM   #91
Microphones are easy. Countryman and a few others make very small heads. The transmitter is another matter. Usually they hang on the belt. I don't know what the NFL uses today but they have helmet radios of some sort.
Mike Rehmus
Mike Rehmus is offline
Old June 26th, 2003, 03:25 AM   #92
Ambient TinyMike opinions?
It looks like a nice small shotgun-type mic:
http://www.ambient.de/p_tiny.pdf
It got quite a favorable review in dv.com:
http://www.dv.com/reviews/reviews_item.jhtml?category=Hardware&LookupId=/xml/review/garrett0402
But what bothers me is the total absense
of any technocal spec on Ambient site, not even
physical size numbers.
I emailed them but got no response on that matter.
Does anybody have hands-on experience with
this mic? How does it compare to Sennheiser
ME66/K6 in terms of directivity, sensitivity, build
quality and overall sound?
Vladimir Koifman is offline
Old June 27th, 2003, 02:10 AM   #93
experience with Azden True Diversity wireless?
I'm wondering what anyone's opinion is on the Azden True Diversity 311DR receiver used with the 31LT VHF transmitter. Anyone got any horror stories? I've been using one for a couple events, and I'm not getting the best sound. Lots of interference (prob cell phones). Sometime I get drop outs as well. Would anyone trust it with a wedding?
Let me know what you think!
Annie Cheatham is offline
Old June 27th, 2003, 11:50 AM   #94
VHF is always going to be problem from interference. The best advice is to check with musicians in your area and find out how bad a problem it will be. If the wedding is in the middle of nowhere MAYBE you won't have problems.
There are work arounds. If you have a minidisc recorder you could sync the mic with the tape by using a clapboard. A better solution is to by a good UHF system like the Sennheiser Evolution 100 series; it is excellent.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline
Old June 28th, 2003, 01:54 AM   #95
senn or azden?
If you are not getting flawless reception you have to change your setup; the question is what to. Cheapest way is probably with md or other deck hard wired to a small lav.
i've not owned a sennheiser but they get good reports other than one person's comments. I'm also in the market and have pretty well set on an Azden 500UDR system. It's worth a look.
on the Internet, when you get where you're going you still don't know where you are
Bud Kuenzli is offline
Old July 1st, 2003, 02:39 PM   #96
balancing R & L separate mics into balanced sound.
If I use an MA-200 on the XL1s so I get two mics on the go. Such as one handheld and one Boom. Whats the best way in Premiere 6.5 to get these two mics to be balanced, ie. handheld on left channel and boom on right channel. Do you just make a copy and swap over channels on the copied sound wave file or is their an easier way. I have heard people say use Cross Pan or Pan across...or words to that effect, however I cannot seem to see that in Premiere.
There is DUPLICATE LEFT but that would just overwrite right with left, right? then that would erase right channel mic. So do I just make a copy them use SWAP to have recorded mic on right and left and Left recorded mic on right and left channels with two wave files for clip. Or is their an easier way?????
I must say I have learned more in here about sound than I ever learned before, as I always had a 'soundman' before in detailed documentary projects and for being soundmen they never seemed to make much sound (speech) towards when trying to understand their roles or needs better. Probably got sick of my questions. But sounds more important than image in a lot of ways. And I want to learn more and more!
So please help me out any Premiere users or Sound experienced people out there!!! Amd that have guided me to websites or put up with my sound questions in past - I'm truely grateful!
Christopher Hughes is offline
Old July 1st, 2003, 06:16 PM   #97
wireless and FCC rules. Problem
it's come to my attention that the new FCC rules regarding wireless frequencies will begin (or are already) encroaching upon current wireless microphone frequencies, including the same ones used by the Azden 500 unit I was about to purchase. Digital systems are currently very expensive. Anyone have any experience with true diversity systems being affected yet? Any thoughts on the issue?
Old July 1st, 2003, 06:33 PM   #98
don't understand the question
When you bring in two channels with separate audio inputs (two different mics) doesn't one come in the left channel and one in the right channel? that would be normal and I don't really understand what the problem is. if you prefer to have both mics in stereo can't you just create two more audio tracks and copy them into the new tracks to provide the listener with the sense the sound is coming from both channels simultaneously?
I use Final Cut Pro and it is trivial in that program (click and create a new audio track and copy/paste) but I can't help with specifics on how to do that (if that is related to your question at all) in other programs.
Old July 1st, 2003, 08:53 PM   #99
Warden
The airwaves are getting crowded and there is little to be done about it. Diversity just allows for better reception if the signals are being reflected of walls etc. The overcrowding issue will be best worked around by the ability to select from hundreds of channels on the receiver and transmitter.
Jeff Donald
Carpe Diem
Jeff Donald is offline
Old July 2nd, 2003, 07:05 AM   #100
Shure A96 transformer
I amin the process of setting up my audio for interviews. Today I went to B and H and they were, as usual, very helpful. They (two different guys) suggested that i get the Shure A96 transformer to go from my SGM-2X to the VX-2000. My question is, how important is the tranformer? I know that it balances the signal and matches the impedance of the signals...
I also realize that i am now in the terrible world of the "hiss", with all of of it's vicious rumors and myths, and truths. Does anyone out there use the A96?
Thank you again,
Marcello
Red means run, son.
Marcello Mongardi is offline
Old July 2nd, 2003, 05:34 PM   #101
For long runs, yes the transformer will be usefull to keep the signal balanced and avoid picking up unwanted noises.
For camera mounted you can wire the mic directly to the mic input using a short XLR->Jack cable. In that case you will run unbalanced but because of the short cable you won't get any hiss.
The A96F will provide a little bit more "gain" compared to a direct connection because of the impedance matching. I use the ME66 that's not a big issue (mic is pretty hot!).
I was thinking about using the A96F on camera but couldn't find any way to mount it (too long and too heavy to stay on the microphone).
Dany
Dany Nativel is offline
Old July 3rd, 2003, 01:14 PM   #102
Sony 7506 ear pad removal
Does anyone know how to remove the earpads on the Sony 7506. I've searched online but can't find anything.
thanks for any info.
Matt Stahley is offline
Old July 5th, 2003, 09:28 AM   #103
*HELP* Need shotgun mic desperately for VX2000!
Hey guys,
I really need a shotgun microphone to help the quality of my films that I shoot on the Sony VX2000. I'm looking to spend about $200-$400 dollars on a shotgun microphone. I need something for short range filming, probably nothing more than 10-15 feet away at any given time. I would like the microphone to mount preferably, but I can deal with a microphone on a pole too. I just need something pretty quick because I need to start filming a project ASAP. I've looked at some microphones, but I'm really not completely sure. Can someone here who owns a VX2000 or knows a lot about them give me some advice about what to buy?
Thanks in advance,
- Joe Calvillo
Joe Calvillo is offline
Old July 6th, 2003, 08:08 PM   #104
Joe - I'm just about in the same boat you are. I'm trying to spend just shy of $200 on a shotgun mic for my GL1 and will also be using it to make shorts (meaning mostly boom work). I dunno if you've read or heard about this review, but it really helped me whittle the field down:
http://www.lafcpug.org/review_shotgun_mic.html
They pretty much review the best prosumer mics there for DV videographers. I've cut it down to the AT-835b, but if your ceiling for spending is a bit higher I'd go for the Senn ME66. People rave about that mic, and I'd kill to get my hands on it! Well, good luck, and lemme know what you decide!
http://devin.par-t-com.net
Devin Doyle is offline
Old July 7th, 2003, 03:14 PM   #105
No Microphone Jack: Is There Another Way?
I bought a cheapie DV RCA 9360 and want to use it to interview people. Although the video output is impressive, the audio is pretty awful. I've got a nice lapel microphone w/battery amplifier. I'm wondering if I buy one of those karaoke players and an adapter, whether I could move speakers closer to the built-in mics and get better results?
Or is there a better way? Money is an object.
John Iler is offline
