On camera mic for HDR-FX1 at DVinfo.net
All Things Audio
Old December 28th, 2005, 12:39 PM   #1
Hi,
I'm looking for a oncamera mic for the Sony HDR-FX1. It should be an XLR type one. And preferably use the phantom power from the Beachtek DXA-FX.
The mic is replacing the stockmic, and is for getting primary realsound but also for soundbytes etc. It's going to be mounted in the camerashoe.
Any suggestions?
Thomas Hartz-Olsson
Thomas Hartz-Olsson is offline   Reply With Quote
Old December 28th, 2005, 01:15 PM   #2
DVCreators.Net
Sorry to be the one to break it to you, but the BeachTek DXA FX does not supply phantom power. I have one sitting here.
So the recommended mics would be:
RODE NTG-2
Audio Technica AT-897
Sennheiser ME-66/K6
All of these operate with a single AA battery.
Or step up to DXA-8, which doesn't quite fit as nice, but does indeed supply phantom power.
Guy Cochran
Old December 28th, 2005, 02:24 PM   #3
oh so the battery is only for the pre-amps?
Oh well the DXA8 is only $70 more. How does it fit compared to the FX? Too wide or too long?
I have acces to lav's and other type mic's that uses phantom power, so that's why it'd be a big plus for me.
Any recommendations for phantompowered mics? Or are your current suggestions still what I should go for?
Old December 28th, 2005, 02:36 PM   #4
DVCreators.Net
The DXA-8 is a bit wider and shorter, but will work nicely with the FX1.
For a lav I like the AT 899 and Countryman B3. The B3 I have requires Phantom, the AT 899 can go either way. Others will probably say to skip the B3 and go for the B6.
For shotguns, it boils down to budget, but I think the reigning champ around here is the AT 4073. Sound nice, it's small and lightweight plus it's a little looser in its pickup pattern than, say a Sennheiser MKH416 - which is a good thing if you're putting it on top of the camera.
Guy Cochran
Old December 28th, 2005, 02:53 PM   #5
As I said I have acces to plenty lav's, so that isn't an issue as of now.
But I'm a little confused here. Possibly just because I'm not completely familiar with the different terms.
What I need is a NON directional microfone - you know like the one already on the camera. Just better and with XLR. And my budget is not big - but I still want a proper mic!
So please bring some suggestions. Even better if you could give me some direct links. Perhaps to B&H. Thanks!
