Shock mount from K-Tek at DVinfo.net
All Things Audio
Old December 8th, 2005, 01:48 AM   #1
K-Tek showed a new mount at the DV Show today, very impressive for the price. This is sub 100.00, I think it's only 60.00, shock mount that will hold most shotgun/small diaphragm mics.Engineered a little differently, but very universal. In fact, it's called the Universal Mic suspension.
K-Tek also showed a new boom that fits into any suitcase or carry on. Impressive little bit of aluminum with internal cable or not.
I don't know if it's on their website or not, but for me, it was one of a very few impressive tools/new toys at the DV Expo show.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old December 8th, 2005, 07:54 AM   #2
They didn't introduce a longer boom in the Avalon series did they?
Marco Leavitt is offline   Reply With Quote
Old December 8th, 2005, 01:58 PM   #3
Longer than 21'? No. You need a handheld boom longer than 21 feet??? (actually, it's 20' 7") That's pretty damn long.
They did introduce a shorter one though. Aluminum, not graphite. According to Mannfred, it would be too expensive to produce in graphite.
Old December 8th, 2005, 02:07 PM   #4
They have a 20 foot Avalon series pole? The longest I've seen is about 9 feet.
Old December 8th, 2005, 02:13 PM   #5
http://www.mklemme.com/pole/k251.html
Old December 8th, 2005, 02:17 PM   #6
Actually, that's graphite. The Avalons are the budget aluminum poles. Can't afford their top of the line stuff at the moment unfortunately. :(
Old December 8th, 2005, 02:38 PM   #7
I'm sorry, I think I misunderstood your post. I don't know what the K-202 is made of. I just meant that the K-202 is part of their professional line. I wish they made an Avalon pole that was 12 feet or 14 feet.
Old December 12th, 2005, 01:51 AM   #8
K-Tek shock mount
Hi Douglas:
Thanks for the news. I just bit the bullet and picked up a CMC641. What shocked me (pardon the pun) about this microphone is how sensitive it is to handling noise. I was wondering if you might be able to recommend a shock mount for it (I dread having to buy a cut1).
I have an AT8514 (not good for this mic), and a K-Tek SM (it's OK if you're very careful). Can you tell me how the new K-Tek might compare to the SM? Or maybe I might be better off with the Scheops mount?
Thank you for any insights and recommendations.
Merry Merry!
Ben
Ben Chiu is offline   Reply With Quote
Old December 12th, 2005, 07:02 AM   #9
We just use the AT8415 and roll off the bass at the mixer. It works fine. We have two, one with K-Tek bands and one with the regular bands. I haven't noticed much difference in handling noise to tell you the truth.
Old December 12th, 2005, 09:05 AM   #10
It's somewhat similar to the 8415, but a little more spread, but the way they've configured the rubber and arms, I'd think it would be slightly better than the 8415 for just a tad less cost. Be sure to order extra rubbers, and you can put a couple extra on the mic. They act as deadeners, and that way you've always got spares, too.
Old December 12th, 2005, 11:18 AM   #11
Shock mount and bass roll off
Hi Marco:
Thanks for the insights. Unfortunately, my mixer (mixpre) doesn't have bass roll off capability. I wondered about those bands too. Now I know.
Thanks again!
Ben
Old December 12th, 2005, 11:20 AM   #12
New K-Tek shock mount
Hi Douglas:
Better and cheaper is the right combination! :)
Good advice as always. Thank you!
Ben
Old December 12th, 2005, 11:39 AM   #13
"Unfortunately, my mixer (mixpre) doesn't have bass roll off capability."
I'm pretty sure you do. This is from the features page for the Mixpre at B&H:
"Low-cut filter switches eliminate noise caused by rumble, wind and proximity effect at 80Hz or 160Hz (user switchable).
http://www.bhphotovideo.com/bnh/cont...ughType=search
Old December 12th, 2005, 12:09 PM   #14
I'm pretty sure you do. ...
Yep - page 6 of the user's manual, in the input panel, labeled "High Pass Filter switch" and discussed in detail on page 9.
Old December 12th, 2005, 12:15 PM   #15
Supports LPFM Radio
>is how sensitive it is to handling noise....I dread having to buy a cut1.
The Cut1 is the way to go. But your MixPre can help a bit. The high-pass filters are on the side panel next to the Mic inputs and below the tape out. If you don't have it handy, you can download the MixPre manual here:
<http://www.sounddevices.com/products/mx2master.htm>
>Boom Poles:
The K-Tek low-cost Avalon line is still settling down. Right now, the Aluminum Avalon poles max out at 9 feet. The Avalon Graphite poles go to 12 feet. And K-Tek's full line goes to 20 feet (or so).
But what I liked at the K-Tek DV Expo booth (in addition to the new mount Douglas mentioned) was the new Avalon Traveler pole. This little guy is 20-inches collapsed and 6.5-feet (or so) extended. Not a long pole, but small enough to fit in carry-on luggage and in common Pelican cases (uh, the 1600 I think?). So it's cool for travelling (hence the name, I guess) and as a compact back-up on doc/ENG stuff.
Also note that PSC has their own new line of boom poles. PSC distributed VdB for years and these new poles, which I first saw at DV Expo, look decent. They vary from quite small (like the traveller) to 17 feet.
Hope this helps,
Jim
Jim Feeley is offline   Reply
