Basic spaced omni/A-B technique - Page 2 at DVinfo.net
All Things Audio
Old November 30th, 2005, 12:22 PM   #16
Originally Posted by Douglas Spotted Eagle
As far as distance, I prefer A/b, where the omnis are less than a yard apart, or X/Y where the heads cross at near angles.
For small rooms, the NOS formation, which is the opposite of the X/Y, as the butts of the microphone cross at near angles, is really useful.
Finally, there is the ORTF combination, where the mics cross each other mid-body at an angle of 110 degrees. This is good for small churches and other mid size rooms, and is closest to the human ear.
I don't use Blumlein, because I don't have a good matched pair of figure 8 mics/bidirectional mics.
Have you worked very much with M/S mic'ing?
Recently I've read a paper from Schoeps about using a double M/S arrangment for surround sound, adding a second rear-looking cardioid to a conventional M/S cardioid / figure-8 array to generate the rear surround, the figure-8 doing double duty for both cardioids. And they also discuss adding a pair of widely spaced omnis with low-pass filters on either side of double M/S array to record the signal for the sub channel.
Steve House is offline   Reply
