Want Advice/Opinions: Next Set of Monitors - Page 5 at DVinfo.net
All Things Audio
Old December 16th, 2024, 08:24 AM   #61
Re: Want Advice/Opinions: Next Set of Monitors
Originally Posted by Robert Lane View Post
My challenge to that is the majority of video consumers listen on earpods, not even low-grade headphones these days, so this creates a whole new issue.
This is a discussion/fortune telling session I've had with several other pros in the past 2 years: We put so much energy into making our final output as visually and sonically as gorgeous as possible (at least the vast majority of us do), yet the buik of the audience is going to see and hear this work on cell phones. Not even decent computers with external audio anymore.
That being said, what's the point of all the work? 6K, 422/10 or 12-bit video? Hah! There's no cell phone at any price that can actuallly display all that data and individual pixels with any accurracy whatsoever.
And being listened to from the same device? Nobody's going to be able to appreciate a solid mix if all they've got are earbuds that can barely reproduce half of the audible frequencies humans can hear, the rest is either sub-sonic or just get turned into digital background noise from all the network compression. Video too suffers from big-time compression, no matter who it comes from. There's just no practical way to distribute even just standard HD at bitrates high enough to really showcase anything close to what we're seeing on our edit screens.
So why all the fuss, then?
Times have and are changing, fast. My hunch tells me the hundreds of millions dollars spent on making our content as close to original as possible is soon just going to go away. If all the world does is watch on mobile devices, not even port over to computers with fibre-download speeds... I think this is all just going to be overkill in less than 5 years.
We'll see...
A lot of kids watch videos with sound muted and rely on subtitles , sometimes subtitles cannot be turned off , and at that point I generally turn off , because I HATE that .
Derek Heeps is offline   Reply With Quote
Old December 16th, 2024, 11:31 AM   #62
Go Go Godzilla
Images: 15
More myth dispelled...
"Speaker Cable", the concept that you have to use purpose-built wire for audio purposes. Total nonsense.
The snooty audio industry has everybody convinced that the high-priced "quality" cable is what you need to get the best signal to your speakers. It's just more glossy marketing, the truth is speaker cable is just like ANY other copper wire out there - it moves electrical current from one place to another. That's it. "Oxygen free", "polarized" and other nose-high terms make it seem you'd better get that stuff or else. But it's just a sales pitch.
Instead, go to your local hardware store and get the largest gauge wire your system can handle, 12-gauge is a good place to start, and spend a fraction of what "speaker cable" costs. I just picked up a 25-foot roll of 12-gauge 3-wire (so you don't use the third wire, so what?) for less than $30 US. Had I picked up Mogami, Monster or any other audio-specific cable, and only 18-gauge at best, would have been over $120!!! C'mon...
This stuff is wrapped with insulation, a smooth soft exterior cover which looks awesome (and professional) and yeah, my speakers are rocking with the high-amp audio come from my receiver. (Now different from the Denon I started with.)
Want Advice/Opinions: Next Set of Monitors-12gauge.jpg   Want Advice/Opinions: Next Set of Monitors-wire-end.jpg
Old December 16th, 2024, 11:51 AM   #63
Go Go Godzilla
Images: 15
Along with the speaker wire I've finally settled on my new audio setup for the renewed edit suite:
A pair of DCM 26 towers, which sound fantastic but I'm going to upgrade the tweeters soon and, a Nakamichi Receiver 2. Very musical and punchy, maybe a tad better than an NAD.
Although the 'michi can be used as a preamp to the Yamaha M45 or other power-amp, it's totally not needed in this setup. I need accurate audio, not window-cracking power. haha
So the test was a success and proved quite definitively:
- You CAN get high-quality, accurate audio monitoring from hi-fi components - that have zero floor-noise or hiss compared to the near-field cousins
- You DON'T have to spend thousands of dollars on a usable setup. This rig in total with the 12-gauge wire was less than $300!! Yes, you have to do your research, shop around but clearly the equipment is readily available.
The caveats:
- High-end near-fields (starting at over $5,000/pair) have their place. They do offer built-in electronic tuning to match the listening environment and the drivers are going to be utterly top-notch without question. Even with the unavoidable small amounts of floor-noise (hiss) they're going to sound amazing.
- Because the equipment used in this test is considered "vintage" you're going to run across equipment that might need a tuneup or have failed components. So keep in mind that while you may find an amazing deal on good stuff you might have the hassle of bringing it back to spec to be usable. But hell, we're still talking a fraction of the cost of even mid-level near-fields!
- Do your research on brands, especially receivers/integrated amps on the ones that actually deliver clean, high-current output. There's a lot of equipment that has tons of features, beautiful faces but don't really provide the quality of output we need for mixing. The best brands are: Carver, Adcom, NAD, Nakamichi, Denon (some models) - anything considered "discrete" or "Class-A" amplifier will do.
Regardless how successful my renewed business becomes I'm never going back to the classic self-powered speaker setup. I'm getting far too gorgeous sound from this "cheap" rig, far cleaner and more powerful than the Focal's I've had.
Cheers and happy holidays to all!!
Want Advice/Opinions: Next Set of Monitors-nakamichi.jpg   Want Advice/Opinions: Next Set of Monitors-dcm.jpg
Old December 16th, 2024, 03:20 PM   #64
What, you don't ground your wooden speaker cabinets? That's just asking for more hum in the system. (J/K)
Don't forget to buy some speaker wire stands, to keep the wire up off the floor, where LF vibrations will induce stray current in the wires. (NOT kidding ... they actually sell this s**t at the high-end hi-fi shows.)
Old January 4th, 2025, 03:48 AM   #65
Go Go Godzilla
Images: 15
Reminds me of flight school at 16yrs old: Instructor told me, "Go get me some propwash...". Took me two hours to figure out the joke was on me.
Old January 7th, 2025, 09:11 PM   #66
Many years ago, my high school band director (I played baritone horn) said, "Tell your parents you want a new embouchure for Christmas."
Old April 30th, 2025, 11:52 PM   #67
Go Go Godzilla
Images: 15
Since this thread got so many views (kinda surprised, actually) I decided to share this announcement with you guy first before I make the formal public announcement in a few weeks.
This past weekend I had an epiphany about speakers as a whole: Regardless if self-powered near-field or passive hi-fi pair nobody has yet to make the "perfect speaker", as it were.
Right, nothing is perfect but I got frustrated of seeing so many offerings touting high-end technologies, exotic materials, years of research blah blah... yet in every case they'd miss the mark in one way or another. Just made no sense that so-called experts would make these often goofy choices in their designs yet still charge hundreds often thousands of dollars for what's supposed to be the best-of-the-best in speaker technology.
So I decided I'm going to make and sell my own speaker series and incorporate all the stuff that my own years of analysis and tests have revealed and use all the tricks I learned that makes for natural-sounding, good-looking and extremely accurate audio monitoring. But not strictly just for those of us in production, but anybody that really cares about getting the best possible sound from their equipment - without having to spend $10K or more on a set.
The new line is called, "Grumpy Quail Audio (TM)". Yes, there's a story behind the name. The first offering is going to be the "BirdStrike Mk1" (TM), a tall desktop-sized monitor but will have the output that would normally come from an enclosure 3x times it's size - a floor-standing tower. And I've created some proprietary tech of my own to get there:
WingTunnel (TM). A structure that does a couple things:
- Provides internal bracing to make the cabinet nearly vibration-free.
- Physically separates tweeter and main driver from each other, so they don't share any airspace and eliminates cross-frequency collisions which can muddy even the best of drivers.
- Makes for a long-path route for low frequencies to travel effectively making the speaker think it's an enclosure 4x times the size which allows for massive and accurate LFE excursion without having to crank up the bass on the amplifier or adding a sub.
- Effectively eliminates port "chuffing" common in many ported enclosures that lack proper cabinet tuning.
BirdBeak Port (TM) - Porting specifically for the tweeter since it does not share any air volume with the main driver.
KISSconnector (TM)
Did you know that banana plugs, while convenient and are associated with "pro" monitors are actually hollow? So that means no matter how big and dense your speaker cable might be only 50-60% of all the electrical energy being sent from the amp is transmitted to the speaker? Why invest in a Class-A amp or receiver if you're only going to send half its' energy to the speaker? Might as well just get some cheap Sony or Pioneer receiver at BestBuy and call it a day.
The final design of the KISSconnector (TM) isn't finalized but it's going to be a SOLID connection, not hollow.
There's a few other things that will separate GQA offerings from all others:
- No MDF materials, only genuine hardwoods.
I can understand that a speaker costing less than say $1,000 would use synthetic/blended wood for cost savings, but when I see "high-end" speakers costing upwards of $10K per copy still using MDF... I just don't get it.
- No mass production process; the entire build is done by hand. No power tools. The catchphrase for the company is, "Modern components meet old-world craftsmanship." (TM)
- All designs are Passive, NOT self-powered.
Regardless how perfect the amp might be there's just no getting around the fact that it's electrically impossible to completely separate all the electrical and RF energy between amp and speaker resulting in "hiss" or floor noise. What's the point in making a perfect enclosure if you're just going to deliver hiss when idle? Besides this way YOU can choose whatever amp you want or can afford. Wouldn't you rather have that choice than be stuck with whatever is inside?
- All designs are ported.
No sound we hear in the world occurs in a sealed room, nothing. So why would you create an enclosure with fantastic components and then prevent them from breathing??! All you're doing is restricting the speaker from doing it's job of reproducing all the frequencies it's supposed to. That marketing hype about having a, "tight, responsive enclosure.."? Total BS. Do you put a piece of shrink-wrap over your ears to hear better? Of course not. Sealed boxes are a really bad design choice, period.
- No A.I. used in the designs.
Computers don't hear audio in the real world, they don't have an inner-ear with stereocilia, or cochlea or inner-ear drum with a stirrup that vibrates or how the bones in our body directly affect how we react to LFE excursions. Even the jawbone and it's connective tissue right beneath the eardrum comes into play when we are listening to anything because it all receives and transmits open-air vibrations right up to the inner-ear components.
(Bet you didn't know that if we didn't have a lower jawbone we couldn't perceive LFE as well as we do, did you? Here's a test to prove it: Next time you're in a club with loud music, a pop-music concert or at a movie theatre or anywhere there's loud music playing try holding your jaw tight with your hands, and then let go. You'll be surprised in the audible difference your ears get.)
No technology can replicate how an organic device responds to vibrations in the air. Mics and oscilloscope testing and frequency charts can't replace the SINGLE BEST question there is: "How does it sound?" Only a human can do that, which requires hours of testing and a LOT of patience.
- No Subs.
Subs are a messy way of making up for anemic main speakers that can't produce enough low-end information. Not to mention when it comes to accurate monitoring for mixing getting a sub placed properly is nearly impossible unless you spend HOURS testing various setups and placements and, it requires not-so-cost-effective software to do it right.
I think it makes more sense to simply have a design that eliminates the need for a sub at all.
The first offering is the "BirdStrike Mk1" (TM), followed by the "MiniStrike Mk1" (TM) and the "BigStrike Mk1" (TM).
It's months away before the first unit ships but will share when the website launches.
Cheers to all.
Old May 1st, 2025, 12:52 AM   #68
Brilliant! :)
Dave Baker is offline   Reply With Quote
Old May 30th, 2025, 03:21 AM   #69
Hi Robert, thanks a month now, how are you going? I’m interested.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old May 31st, 2025, 01:02 PM   #70
I just re-read Robert's post. I disagree with so much in it, I don;t know where to start.
MDF is really good structural material. Consistency between batches, and it is very high on the denseness scale. Hardwood, by comparison is very inconsistent - different batches having wildly varying weight and moisture content. Speaker manufacturers need every cabinet to be the same. MDF is not as tough as hardwood of course, so less good for things like PA cabinets, where plywood solves the rigidity and the strength issues.
I'll pick one other bit - the statements about the proximity of amp and speaker drive coils creating hiss. Stray magnetic fields creating hiss? Low frequency energy is NOT RF energy - it's electromagnetic, and proximity between magnetic field and something with a coil would indeed be possible. However, it would be bass, and very low bass that could couple. Hiss is only feasible if wide band noise was radiated, and as the energy drops off with frequency, any hiss you hear is simply a hissy amp. Poor electronics, or bad design, or simply terrible gain staging so the driving audio is too low, so the monitor gain has to be turned up.
This is common hifi technospeak - a little physics bent to fit the desired result.
An amp, then decent cross-section cable and then then the speaker, or line level audio to the powered speaker makes no practical difference. Years ago, we had Quad mono amps, and we put them close to the speakers, but then we started putting amps further away. It really doesn't matter in any practical sense. Poor amps, driving long speaker cables do their job less well - but that is amp design not the overall concept.
The audiophool fraternity, take a bit of physics and warp it. Sometimes ridiculously. Having been in and out of broadcasting and recording studios all my life, few buy and install equipment based on anything other than solid audio engineering practices. Never audiophile practices. The BBC, when it had huge engineering departments doing R&D designed some excellent stuff. They spent a lot of time considering audio going down cables. Resistance, impedance, capacitance and inductance. Those 4 things were what was important. None of the arrows on cables, oxygen free, or crazy spaced techniques. If there was no off the shelf product, they designed one, gave it a spec number and people like Canford sourced and sold it - to anyone! No precious metals on connectors, just regular cleaning and maintenance.
Loudspeakers just sound different. My own take on it is that very often going wow - like the B&Ws in this story, means the speakers are adding something of their own personality. The dead opposite of what they should be doing - being truthful. If you buy an expensive audio analysis system, you get a box of electronics to generate test tones, and a wideband, usually omni microphone to hear what comes out of the system. It then shows you all the humps and bumps you didn't know you had.
If you ever record music with that measurement mic - the one with a carefully crafted virtually flat frequency response - it sounds dreadful, No character, no musicality at all. This is why (I think) some speakers sound great and others are sort of a bit boring.
I'm not knocking the belief in this stuff - people can believe what they like, but some things are just wrong to promote as factual, when they're just opinion. The hifi folk are often on totally different planets to the rest of us.
Sorry - but the idea a really poorly designed amp actually sends hiss through the air inside the cabinet is just bent physics.
Old June 2nd, 2025, 04:27 AM   #71
Hi Robert, as much as I like to see a new product successfully enter the market, especially from someone who’s never been there before, your entry shows itself as being ‘pie in the sky’ totally bereft of any serious research, proper testing, and most of all serious market research.
The audio speaker market is well saturated with product of all types, styles and prices. A few years ago RØDE in Sydney introduced a new book shelf speaker. I went out to the factory in Silverwater to hear it, sounded great. But they never went ahead, why? market competition, there’s just too much of it.
But what did Peter Freedman do as the next best thing? Buy a company that makes them. So in 2003, RØDE bought Mackie in the U.S.A, alongside Mackie, they now own APHEX, Event and SoundField.
So tell your rich uncle you’re going to try something else. However if you do pull this off, I’ll be the first to congratulate you.
Best of luck. Cheers.
Old July 9th, 2025, 10:26 PM   #72
Hmm. Sorry but that's a swing and a miss.
I've sat at a table with Robert over dinner and drinks and I'm pretty sure he's close to my age. There was a time, way back when I was much younger, that I had a rather broad variety of uncles and one of them was in fact actually quite well off. But that's a story for another time. My point is, I've just realized I have exactly one uncle left in my life, and he's in his late 70's.
Just saying, there's a lot of old geezers around here -- after all, I'm one of 'em -- and for most all of us, rich uncles are quite honestly now very much a thing of the fondly remembered past.
I mean, I'm somebody's uncle, but I think I'm referred to as the drunk one. I'm not quite sure.
Old July 9th, 2025, 11:07 PM   #73
Go Go Godzilla
Images: 15
...and for me there is no uncle at all. I've been a lone wolf from "family" since 14. So whatever I do and have done has been on my dime, nobody else's.
Hey Paul,
Appreciate the chime-in but engineers at NAD, Wharfdale and others would dispel at lot of your own assumptions based on the many conversations I've had with them.
That being said as I mentioned months ago in this thread, the bottom line is, "how do they sound" to human ears. There's technically perfect and then there's a sonic representation that both engineers and experienced editors alike are keen to call "accurate". Like anything else that's based on our human frailties and differing bodies - opinions differ.
Specifically to MDF or not... there is a distinct vibrational difference between artificially sandwiched materials vs. natural hard-woods. The simple reason it's still used in "high-end" enclosures is cost of manufacture. MDF cuts far easier than hard-woods and is easier to repair when nicks occur.
Plus for me the target audience for the GQA monitors isn't the general marketplace where 80% percent of us would sooner spend less than $400 on a "good" pair to mix with, whereas my market wants both sonic accuracy but aesthetically pleasing exteriors that only natural woods provide - no laminates over MDF.
However the "MiniStrike Mk1" will address the budget market while keeping the core design schema in place. I'm hoping to deliver them at less than $800/pair to compete with the common self-powered units we're all familiar with - me too. I mean I cut with Focal, JBL, Adam and others for decades and was pleased with them all. I'm simply going after a higher target of quality without raping people's wallets.
To wit the first prototype of the "BirdStrike Mk1" has been met with rave critical reviews from these same engineers - of course with feedback. (pun intended - haha) So the core of my design philosophies are so far hitting the mark.
We'll see how it's handled by the marketplace when it finally goes up for sale.
Time will tell - that damned clock never stops.
Best to all.
Old July 10th, 2025, 12:49 AM   #74
The engineers at these companies have a bias built in. They are hifi engineers. They select particular bits of science to reinforce certain beliefs held by their customers. It is very common to find engineers who have the same education who produce contrary conclusions. We have to select which conclusion to accept. I choose to not believe any person or company in the business of selling expensive equipment to people who have certain viewpoints.
Monitor speakers should reveal defects in program material, that we can then base judgement on, and hopefully fix, so the output is received well by the entire audience, listening on a massive range of home equipment from dirt cheap and horrible, to the audiophool community.
Broadcasters, with deep pockets never buy hifi expensive equipment. They buy specific brands that meet standards they set. For years, broadcasters have specified certain kit. Freelance camera folk had a quite short list of acceptable cameras, and sound recordists had the same. Lighting people would use common kit. Few risked trying to use a boutique camera, or some exotic microphone, or unusual lighting fixture.
This is why certain brands proliferate. In an OB truck, the audio will come out of a small Genelec. Why? Because it is a standard sound that people know and can adjust to. The people who take that Genelec moxed audio can use it. Lots of compact hifi speakers could be used, and would fit. They are designed to sound nice, not accurate. Different market, different performance, and usually out of balance cost.
Engineers, as a profession, often get it wrong. Remember the Hubble telescope? They also have a salary so is it surprising the hifi company engineers support their companies position.
I distrust 100 percent of any ‘science’ from people selling things.
Old July 10th, 2025, 06:20 AM   #75
No uncles here, my family is all dead and gone for many years now. But I'm my own Grandpa!
