Opinions on JBL Control 1 monitors? at DVinfo.net
All Things Audio
Old November 6th, 2005, 01:51 AM   #1
Guest
Posts: n/a
Hey everyone,
Just wondering what you think of the JBL Control 1 monitors as budget monitors? I'd get a subwoofer with them as well.
Cheers
Frequency Range: 70 Hz - 20 kHz (-10dB)
Power Capacity: 150 Watts (test signal of IEC filtered random noise with a peak-to-average ratio of 6dB, 2 hrs duration)
Sensitivity: 87dB 1W, 1m
Nominal Impedance: 4 Ohms
Crossover Frequency: 6 kHz
Components: 135mm (5 1/4 in) low frequency loudspeaker 19mm (3/4 in) polycarbonate dome tweeter
Enclosure Material: Structural Foam
Finish: Black, Gray or White
Termination: Spring Terminal (adapted to accept dual banana plugs)
Dimensions (HxWxD): 235 x 159 x 143 mm (9.25 x 6.25 x 5.625 in)
Net Weight (each): 1.8 kg (4 lbs.)
http://www.jblpro.com/pages/recording/control.htm
Old November 6th, 2005, 05:00 AM   #2
I had a pair, but they are not very accurate, and best used for checking how your mix sounds on consumer gear. I compared them to a pair of Edirol MA-15D and these powered speakers where better and more vesatile.
I ended up using the JBL's in the kitchen, and finally sold them to a friend, who's using them in his bar.
Maybe a set of M-Audio LX4 would suit you better. They are a powered 2.1 system.
12c41
JOS. Svendsen
Jos Svendsen is offline   Reply
