#16 | |
Re: Converting mp3 to wav for editing purposes
#17 | |
#18 |
Kathy - you are worrying about nothing in real terms. I finished a project and delivered it - client happy, and it was a music product, so quality was vital. I'd done 5 previous ones and 2 more afterwards. Three months later, I was using it as a template and noticed the filename in the Premiere clip collection - audio23v2.mp3 - I'd used the mp3 clip instead of the 48K wav I should have used. Even worse - that track is also in iTunes, Spotify, apple etc - and they were all delivered from the same source file - usually a 48K 32 bit .wav, but this time a 48K 320 mp3.
What you need to do is recreate the project using the mp3 and the mp3 converted to .wav and see if you can hear it. I suspect very much that you can't. If I load an mp3 and a wav into premiere, in my edit system I have to look at the screen to tell which is which. There are differences, but when you export your video, it is re-rendered anyway - so it seems foolish to convert the mp3, then have that converted again when layered into the video. Just try to ensure the next one is what you want. Conversion is always going to be at best - a copy, bit for bit, or a data reduced version. The quest is to keep the output file as close as you can - so reduce conversions, but I suspect that the receivers of the file would not notice if the mp3 is a 320 version instead of a lower one. I suggest you simply try the process and then audition the results. I suspect you will have trouble determining which is which. Some audio content degrades badly with bit reduction and compression - others survive fine. |
#19 |
It's the old saying. You can't make a silk purse out of a pig's ear.
Regardless of the quality of the incoming MP3 files the best way to maintain their inherent quality, whatever that may be would be to convert them to full 64-bit float WAV files for your edit / sweetening exercise. For example if the original audio was recorded at 192 kHz frequencies of up to 96 kHz in the original audio would be recorded. Whether those frequencies are present in the existing MP3 files would need to be determined. While working on a project, it’s not a bad idea to work with a higher audio bit depth. Because the noise floor drops, you essentially have more room before distortion occurs, this is known as headroom. Having this extra buffer space before distortion is a good failsafe while working and provides more flexibility. You could finish up exporting your final sweetened files as full 64-bit float WAV files but one has to remember not all application can handle these files. The noise floor, even in a 16-bit system, is incredibly low. Unless you need more than 96 dB of effective dynamic range, 16-bit is viable for the final bounce of a project. As most would know and understand the most common delivery format is 16-bit 44.1 kHz. Chris Young |
#20 |
Kathy,
It seems to me that a few people are missing your question, and telling you things you already know. Please allow me to contribute my 2¢ worth toward answering your question. I hope I don't sound condescending or repetitious. I completely agree with Don Palomaki: the degradation happened when the original audio was compressed to MP3. No [significant] further degradation occurs when it's uncompressed to PCM. But further degradation will occur when the finished PCM is compressed into the final MP3 format. I know of a few programs that can edit (i.e. cut, paste, delete) MP3 files without transcoding (specifically, the final file will be the original file with some number of bytes added or removed). Even changing to a different bitrate involves transcoding. I say the above to make a distinction between editing and audio alteration. I doubt that any program can actually alter the sonics of an MP3 file without first transcoding to PCM/WAV. Such alteration would involve operations on the PCM audio data, so the altered part would not contain any of the original bytes. By contrast, a truly edited MP3 file would contain the exact original bytes, minus any bytes that have been edited out, and plus any bytes that have been pasted in; nothing is transcoded. I'm curious about Rick Reineke's comment that some editors do not overwrite the original file. Is this true even if the finished (edited, processed) file is saved using the original file name? If you "open" an MP3 file in a program such as Audition (or the predecessor Cool Edit) the "opening" process is really transcoding from the compressed file to uncompressed PCM in RAM, where the audio processing will take place. You can confirm that by starting with any [relatively lengthy] WAV file, Saving As MP3, then closing everything. Re-opening the MP3 file will take more time than re-opening the WAV file; that extra time is the transcoding time. I don't know the content of the audio, but for example IMHO a mono MP3 at 96kbps is entirely adequate for use in a voice podcast, or even for location news gathering, etc. After all, it's not for playback in a THX theatre. To expand on what Paul Johnson said: start with some given WAV file, convert to MP3, close both, reopen both, and subtract one from the other in your audio editor. That will let you hear the difference ... you will hear some artifacts that would normally be covered by the desired audio. It's an instructive experiment. But it won't have any effect on your workflow for this project. Given the above, just open the file in your editor and it will end up in RAM as PCM. No need for separate conversion. Then do what you have to do, and save in whatever format the client needs. And save your final WAV in case client wants further work on this same project. The end. Peace, out. PS: What ever happened to that long room with the glass wall and low ceiling? Last edited by Greg Miller; November 2nd, 2021 at 02:56 PM. |
#21 | |
OTOH, most 'multi-track' DAWs creates high-res and floating point bit depth PCM proxy files for the timeline, leaving the original files untouched. A new master mix file is eventually rendered. Sound Forge Pro is not a multi-track application like ProTools, Audition, Reaper, ect, but has a project file mode option, which is similar to multi-track applications so the original file(s) are never overwritten. There are other options in SF to maintain lossy file quality as well. All options have are pros and cons, so it depends on the project, file types and workflow preference. btw, I am a Magix tech forum moderator and on the beta test team. MAGIX Software GmbH acquired the Sound Forge, Vegas and Acid products from Sony in 2016, which were originally developed and published by Sonic Foundry, USA in the 1990s. |
#22 |
It boils down to one has to know what one's software is doing. In general a SAVE will overwrite the original file (hopefully with warning) while a SAVE AS allows you to save under a different file name (keeping the original). It may also allow you to change the file format.
The 44.1 K sample rate and 96 kbps is not especially close to the maximum MP3 potential of 48 K sample rate and 320 kbps data rate. However, the success will depend on the material being encoded. Speaking voice generally does better than complex music at lower sample and bit rates. MP3 uses psycho-acoustic coding techniques to drop audio detail that is considered less important to the file playback. A potential issue is that editing efforts such as equalization changes may want to work with some of the detail that was lost in the original MP3 compression. That could sour some of the sweetening prospects. Any saves should be to a lossless intermediate file (e.g., uncompressed PCM /WAV). of suitable bit depth. The final action would be export to the desired distribution format.
dpalomaki@dspalomaki.com |
#23 |
Thanks, Rick. That is pretty much as I expected.
There is one program that I use for non-destructive *editing* of MP3 files, without audio manipulation. It's called Total Recorder Pro. I'll describe a few scenarios. Open File1.mp3 Select and delete any part(s) to be removed. Repeat as needed. Copy and paste is also possible if you need to move some piece of the audio to a different place in the file. "SAVE AS NewName.wav" will create a new file (as you'd expect). All data from the original edited file will be transcoded to WAV and saved as a new file. (Output file can be anything other than original File1 format and bitrate.) Open File1.mp3 Edit as in first example. "SAVE" will save back to the original file. It will NOT transcode any of the audio. If the edited file is shorter, of course the final length of File1 will be shorter than it was originally. But it's just a byte-for-byte process. Some bytes will be removed, but the remaining bytes are just the exact bytes from the original file. Open File1.mp3 Edit as in above examples. "SAVE AS NewName.mp3" will create a new file. The contents of that new file are copied byte-for-byte from File1.mp3 (minus any edits and trims) ... NO audio is transcoded (unless bitrate is changed). The first example is what you'd expect. The last two examples are the feature I really like: no transcoding. The resulting file is as clean as the original, and the process is much faster than transcoding. Total Recorder Pro also has a lot of recording functions including direct data capture from any source, before the audio goes through the sound card. It has timed record, as well. I've been using it for at least ten years. The program costs $35.95, which includes free lifetime upgrades to newer version numbers. |
#24 |
In your original post you mentioned eq and denoising. I doubt you can do those without decompressing.
