What is the best way to fix this. - Page 2 at DVinfo.net
All Things Audio
Old August 18th, 2021, 12:11 AM   #16
Re: What is the best way to fix this.
If you have basic soldering skills, you can fix these quite simply. The kits are the simplest, but I’ve seen people simply drill out the old antenna, pop in a new length of wire, solder it to the pad and then seal with a drop of CA. Trim to length and do it again in a few years. Remember performance relates to the performance of the metal component, not the prettiness.
