Monitoring audio recording wirelessly?
Hi guys,
During weddings I plug into the DJ's/Venues mixing board to record audio for using in wedding film. However, as DJ is in a separate corner, I have to constantly run back and forth to monitor audio recording levels. I have been thinking if there is any kind of field recorder that I can monitor/adjust the input gain on it wirelessly from distance? Thanks! |
Re: Monitoring audio recording wirelessly?
Good news/bad news. The one I bought with the hopes of doing the same is the Tascam DR-22WL (Wireless). https://tascam.com/us/product/dr-22wl/top
It does have an app that allows you to remote start/stop and monitor levels, but I found it extremely buggy. The app takes a while to connect sometimes, or just drops the connection. The ad-hoc network it creates is weak, at best, so you can't roam too far, it seems. My advice, get a Tascam DR-10x, which has (decent) auto levels and a safety track recording. It's not a guarantee of success, but it ups your odds. Make sure to update the firmware, which now allows continuous level monitoring (levels display used to disappear in the previous firmware). |
An approach would be to connect the DJ output to a wireless mic transmitter; e.g, a RODE Newsshooter, and carry the recorder with you connected to the receiver.
dpalomaki@dspalomaki.com |
The Zoom F4 and F8 levels can be monitored and controlled remotely using an Apple device (no Android support unfortunately). They also have a dual-record function that lets you record one input on two channels set at different trim levels so you can pick whichever sounds best.
#5 | |
#6 |
This is what I've been using, Tascam DR44 WL, and it has worked well thus far. If distance is an issue, I've noticed that my wife's larger iPhone 7 picks up signals better than my small iPhone 6, so that may be something to check.
Really like the ease of use because the VU meters are clearly visible and one can adjust the levels on the fly, start, pause, and stop, Edit: The safety track is active in the picture. |
#7 | |
How good is the wifi range though? I would like it to work at least up to 30 meters but I read in reviews range is only 6 meters... |
#8 | |
Zoom F8 + G3 IEM Then you can monitor in stereo, and over bluetooth control and see all the levels. I've done basically more or less this approach myself a number of times (for instance it is very handy for 360VR recordings, when you must drop the recorder under the camera itself but you must be hidden from sight). Only downside is the range of bluetooth sometimes is not enough. If I knew I needed much more then I'd rent/buy a Sonosax SX-R4+ which can be controlled over WiFi.
http://IronFilm.co.nz/Sound/ (Location Sound Recordist based in New Zealand) http://www.YouTube.com/c/SoundSpeeding |
#9 |
And why can't you run out cables to a better location? With an unobstructed view.
