cable pad to wire a line output to a dslr at DVinfo.net
All Things Audio
Old April 11th, 2018, 11:10 AM   #1
can anyone link here a clear detailed scheme to build a TRS cable with 25 - 30 DB pad to wire a recorder line output to any mic in on reflex?
we are working on a corporate project, with basic interviews requiring a canon 5d and a lavalier and a boom, the bag with sound devices 664 is going to be so heavy and cumbersome so I thought to use a Tascam dr100 and wiring it directly into the canon 5d
the line output impedance on the tascam dr100 is 200 ohm, how much is the canon 5d mic input impedance?
David Aliperti is offline   Reply With Quote
Old April 12th, 2018, 12:05 AM   #2
Re: cable pad to wire a line output to a dslr
You could just buy an off-the-shelf commercial attenuator like this....
https://smile.amazon.com/dp/B000ZLX2TU
Or, if you want to make one (with a few pennies worth of resistors) built into a connector, one of the better references for building a pad is Rick Chhinn's website:
Uneeda Audio - Build your own attenuator pads
Richard Crowley is offline   Reply With Quote
Old April 12th, 2018, 12:43 PM   #3
I need to know the precise impedance of the canon 5d mk3, what scheme is the right one considering we are relating to a TRS unbalanced stereo connection?
Old April 15th, 2018, 11:35 AM   #4
I use cables like this one for connecting the mini-trs line out of audio devices to the mic input of dSLR's and other recorders.
https://www.bhphotovideo.com/c/product/906960-REG/kopul_ach4_25mon_line_to_mic_attenuator_cable_with.html/BI/2855/KBID/3801
That one above has a headphone output Y, but you can also get them with just a straight connection without the headphone jack.
Jay Massengill is offline   Reply With Quote
Old April 15th, 2018, 11:42 AM   #5
I have just purchased this one
https://www.ebay.it/itm/SAA40-Stereo...QAAOSwajRZbGAI
Old April 15th, 2018, 11:53 AM   #6
Let us know how it works out. I had not seen that brand and variety of boxes.
