Audio mixer setup, panning ??? - Page 2 at DVinfo.net
All Things Audio
Old November 18th, 2016, 12:01 PM   #16
Re: Audio mixer setup, panning ???
Originally Posted by Jonathan Levin View Post
in this case my lav is 8-10 inches from mouth and the boom is just above head out of frame, but far less than the 3 feet if following 3-1. More like 2 feet.
Again my lav falls between -5 and +8 tops on the SD 633. And the Boom somewhere around -25 to -18.
Your distances (8" and 24") are exactly what I assumed when I came up with my previous numbers.
Your ears are probably correct. If you're keeping the boom track 20dB lower than the lav track, the phase issue will be negligible. Personally, I would slide it anyway, just because I'm a compulsive nut. But you probably don't need to bother. Stay calm and carry on!
Greg Miller is offline   Reply
