Storm sounds - Page 2 at DVinfo.net
All Things Audio
Old May 19th, 2015, 10:28 PM   #16
Re: Storm sounds
I do indeed remember the sheet metal. When I took 7th grade shop class we thought it was great fun to play with some old sheet metal to make thunder. I was just afraid nobody would believe me!
Old May 20th, 2015, 03:35 AM   #17
Re: Storm sounds
Thanks everyone...I have some things to try! I'm onto another episode in the series so will have to go back to it...
I have Rose's book 'Great Sound for Digital Video' but haven't looked at it in a long time. I got it and went through it all when I was 'learning'. Maybe I need to look at it again... :-)
Renton Maclachlan is offline   Reply With Quote
Old May 20th, 2015, 03:42 AM   #18
Re: Storm sounds
Hi Greg
Re your clipping sound example...hmmmm...I'm fully aware that after a life time of running power tools (many years without earmuffs!!!) I've lost some of my hearing...however...I can't hear any distortion, just increased volume. Maybe the distortion is in a frequency that I can no longer hear...
Old May 20th, 2015, 06:22 AM   #19
Re: Storm sounds
Don't you hear the additional upper harmonics created by the clipping?
Here's a spectral view. The single red spike is the 440Hz fundamental from the first tone sample (the one at -6dBFS). The green spikes are the harmonics added in by moderate clipping in the second tone sample. The blue spikes are the additional (and higher level) harmonics added by the heavier clipping in the third sample.
The distortion products start with the second harmonic, located at 880Hz. Surely you can hear that frequency, or you'd be unable to understand speech. The first really loud harmonic is the third harmonic at 1,320Hz. Again, you need that frequency to be able to understand speech.
If you still can't hear these when listening closely, maybe I can devise another example file.
Greg Miller is offline   Reply
