#16 |
Re: Lowbudget solution for voiceovers/podcasting
The only thing to watch with USB mics is that the gain settings are often fixed, and a bit low - so you need to get in perhaps a little closer than idea.
#17 |
+1 on Richard's AT2020 USB suggestion. For that matter, I've done nice voiceovers using a "lowly" Samson C01U.into Final Cut. Any of the USB mikes will most likely be better than a conventional mike going into your computer mike input. For more bucks you can get a Presonus or MOTU or equivalent a/d converter and a conventional mike, but why bother?
#18 | |
Regards, Ty Ford |
#19 | |
Steam Age Pictures - videos in aid of railway preservation societies. |
#20 |
Try this for a DIY sound booth - open the doors of a wardrobe, spread a quilt or blanket over the doors to make a roof, face the rail of clothes... The real problem is getting far enough away from the computer that you don't have its hum and whine in the background.
When I've made voice-overs, I've used my camcorder as the recorder, then imported the clips into my NLE just like normal video. It helps that the camera has XLR sockets and phantom power, so I can use a "proper" mic. I sit the camera on a cushion a few yards away from the "booth", which is enough to stop the mic hearing the tape motor (yes, still using tape!) and point the lens at a clock with a second hand, which gives a visual cue to help when scrubbing through the clips. I have an old AKG C1000 condensor mic in a simple crossed-rubber-band shock mount, the Heath Robinson pop-shield I described earlier and a music stand to hold the script. It's not perfect, but it works well enough. You could probably hear how it was done on a good hifi, but not on most TVs and certainly not on YouTube ;-)
#21 | |
Ty Ford |
