#16 | |
Re: Proposing a $2K "Fix" to Boss for Distance-Learning Solution
#17 | |
I think I'll do this: I'll use a http://www.bhphotovideo.com/c/product/547632-REG/ART_SPLITCOMPRO_SPLITCom_Pro_Microphone_Splitter_Combiner.html to create "doubles" for each channel on the mixer to get six microphones (maximum of 12 students) fed into the mixer. One channel is exclusively reserved for the instructor (lavalier mic). Thoughts?
HD Rookie here... |
#18 | |
HD Rookie here... |
#19 |
There are many gated mic mixers on eBay, many for under $100.
Of course remember this: if you're also running the instructor through the gated mixer, then if one of the students coughs while the instructor is talking, that "cough" might take over the audio and mute the instructor's mic. Just saying... I, too, would like to see a stand that's heavy enough to be stable with an 18" gooseneck hanging off to one side of it, and a clip that will securely hold on to an XLR-size shaft. Quite likely the appropriate hardware exists somewhere, I just question whether finding the right stuff is trivial or inexpensive. (Then again, that's when you call your dealer and tell him what you're trying to do.) |
#20 |
Rent a conference gooseneck mic system, as are commonly used on large governmental (like they use in the senate or corporate board meetings) where the gooseneck mics have push to talk function and are scalable depending on number of participants. you can also use something like a Biamp Audia flex frame with 24 AEC (auto echo canceling)mic inputs such as are commonly used in high-end video teleconference systems ( which I design for a living) however this is not cheap solutions but are designed to specifically address this particular situation.
There are many options the details of the rooms and where participants will be seated really make a huge diff in what the best approach will be, very do-able, I have done large meeting halls with hanging mics that are attached to a VTC system where the audio from audience sounds as good as a small office speaker phone call. so its possible but budget dictates quality here, oh yeah not to mention physics. for $2k... rent |
#21 |
Project Update
Last week I scored a literal steal on Ebay and was able to pick up *two* Shure SCM410 Automatic mixers for only $65 each! To add, I ordered a linc cable to turn them into a 8-channel mixer and a rack mount from Shure to install in my rack case.
These mixers are usually $700 new, $250-300 used, so I got a great deal. Again, this is a project to close-mike six students (to start off with) for integration in our audio feed to distance-learning students via live streaming. We have decided that one microphone per student will yield the best quality. Now all that remains is to purchase the rest of the equipment, which will amount to a bit below $1K: Shure Centraverse Condenser Gooseneck Mics: $600 (Six.) Hosa Audio Snake: $120 (One. Connects several mics.) Microphone Cables: $120 (Six. Connects mic to snake.) Microphone Clips: $50 (Six. Allows mic to be positioned.) Microphone Clip Mounts: $50 (Six. For desk mounting clip.)
HD Rookie here... |
#22 |
In my world, a mic for casual pickup of audience reaction isn't worth $100 each.
I would at least compare that $100 Shure mic with the similar $33 Pyle mic. http://www.amazon.com/Pyle-PDMIKC5-P...YFSRPJKQKHJREN At that price difference you could buy 3x the mics for the same budget. |
#23 |
Also consider sound treatment in the room. A few absorption panels can make a big difference.
#24 |
My only question about the Pyle mic: what is the output configuration?
The "user manual" is a joke, it refers to a wireless system, which this certainly is not. At one point the specs say output is 200 ohms, at another point it says 600 ohms ... that's fairly trivial. But most important, is the output balanced or unbalanced? There is reference to a cable with XLR(F) to 1/4"(M). Is the 1/4" connector TS (unbalanced) or TRS (balanced)? You want to be sure this mic is compatible with your mixer; at the very least you might need different cables. Also, this mic requires a 9V battery, so be sure to have spare batteries on hand when you go into a session. (Ideally you would put a fresh battery in each mic, for each session ... at least until you have accumulated some data on useful battery life with this specific mic.) FWIW, there is a similar model PDMIKC6, which uses 1.5v AA cells instead of a 9V battery. If nothing else, the AAs should save you some money. The output impedance is listed as 2.2k ohms, but again, I can't find any info about whether the output is balanced or unbalanced. IMHO, read the "manual" for the PDMIKC5, consider the conflicting and incomplete specs, and draw your own conclusions. The mic itself might be just fine ... even a great bargain ... but I think I'd order one for evaluation, rather than ordering six of them sight unseen. |
#25 | |||
#26 | |
If the mic and cable are unbalanced, we don't know the pinouts at the mic end. (In fact it may just be single-conductor shielded.) Worst case, if it's unbalanced, it may use only two pins of the XLR on the mic body. So a standard balanced cable might not work. This could be accommodated one way or another, but a rather non-standard cable might be needed. Also, if it's unbalanced, it's very important that the mixer doesn't put out any phantom voltage. These are just details ... but they're important details. Agreed, in theory. Still, I read one user review that said the power switch got stuck in "on" position causing premature battery failure. (I don't know what "premature" means in terms of hours.) My point is that it would be wise to have some spare batteries on hand, just in case! |
#27 |
Re: Project Update
