Boompoles with coiled cables. Are they noisey? at DVinfo.net
All Things Audio
Old June 26th, 2013, 05:51 AM   #1
I'm looking at an upgrade to my boompole and blimp. I've settled on the Rycote S-Series. The Rycote A5CC boom pole looks interesting with it's built-in coiled XLR. Speed matters.
Anyone used this boompole? Are poles with builtin cables any harder to control handling noise made by the cable? TIA
Old June 26th, 2013, 07:57 AM   #2
Re: Boompoles with coiled cables. Are they noisey?
I have a k-tek with an internal cable and side exit and it is not noisy at all. Sure if you are rough with it you can get some noise but if you use it within the normal handling parameters it is silent.
Take a look at a side exit for the main section. It may save you a bunch of broken XLR cables.
http://www.LandYachtMedia.com
Old June 26th, 2013, 08:29 AM   #3
Anyone used this boompole? Are poles with built-in cables any harder to control handling noise made by the cable? TIA
Internal cables are an American thing and are popular in the USA.
In the UK we tend to use external cables to reduce handling noise.
Internal cables can be OK, but a cable problem means that you lose the boom and they can get noisy over time as the internal foam disintegrates.
But the Rycote *is* a good pole and the price is reasonable.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old June 26th, 2013, 08:43 AM   #4
Glad you mentioned the K-Tek. They have a nice one for traveling (79CC). But best I can tell, it has the usual twist mechanism vs the Rycote one that seems to take less twisting. My current inexpensive pole is a pain to grip the stationary part in order to twist unlock. I assume the Ktek is a higher quality. How's the K-Tek twist mechanism?
Old June 26th, 2013, 09:05 AM   #5
I've not had any problems with the section locks. They have a texture and are pretty easy to grip. You don't need to put a lot of pressure on them to tighten them up. If you do they are difficult to loosen.
Old June 26th, 2013, 12:06 PM   #6
+1 for K-Tek. I've got one and have had no issues. However, if you did experience 'noise', you can always 'by-pass' the internal, coiled cable and wrap the XLR cable around the exterior. Best of both worlds.
J.
James Kuhn is offline   Reply With Quote
Old July 15th, 2013, 07:42 AM   #7
When I first bought my K-Tek internally cabled pole I was very alarmed at how the cable seemed to rattle when I moved it, but in practice it has never been a problem. It takes a pretty good shake to make it rattle, and in that case your mic would probably flop around on the shock mount and make even more noise.
Marco Leavitt is offline   Reply With Quote
Old July 15th, 2013, 08:22 AM   #8
Not so much noisy, but hard to manage being tethered physically to the camera..
I use a radio transmitter plugged into the grip of the Rode Blimp, on or off the boom pole.
Ben
Ben Longden is offline   Reply
