Trim levels - Page 2 at DVinfo.net
All Things Audio
Old May 28th, 2013, 12:24 PM   #16
Re: Trim levels
It varies by model, as I recall the EX1 does not have a switchable limiter. The EX1R and EX3 does have a switchable limiter.
Not to be confused with AGC, which most audio people DO NOT LIKE.. OR USE.
Old May 28th, 2013, 12:40 PM   #17
Slash Rules!
Re: Trim levels
Oh ok. So "R" and 3 only. I have a client who has the original EX1. So I guess no worries then.
Old May 29th, 2013, 08:32 AM   #18
Re: Trim levels
Hey Roger,
Hope you figured this out before your trip. Trim in this case is allowing you to match your microphones output to a range where the input knobs will work well for you. -41DB is not unusual for a mic so if you like the range you are getting you are good to go. Professional Line Level is usually +4DBU, Consumer Line level is -10DBU and Mic Level can be anywhere from -30DBU to -60DBU so the trim would give you the opportunity to cover a wide range of outputs from various devices if used properly. When using a 416 Phantom power on my HPX 2000 I have to set the mic level trim to -40 instead of its usual -50 to avoid distortion on the peaks even using Auto gain. This is probably the case with what you are doing. Since you had too little signal at 0DB setting the trim to -40 increased the inputs sensitivity. If you hear the sound clipping on input decreasing the sensitivity by setting the trim to -30db might help.
Daniel Epstein is offline   Reply
