SK 100 G3 Battery Powering at DVinfo.net
All Things Audio
Old November 20th, 2012, 02:41 PM   #1
Sorry for the crappy subject title. I'm trying to find out how to power my Senn. G3 Transmitter body-pack from my Remote-Audio BDS? My audio kit is powered by an NP1 style battery. I'm sure there is a cable that will accomplish it.
J.
James Kuhn is offline   Reply With Quote
Old November 20th, 2012, 03:55 PM   #2
Re: SK 100 G3 Battery Powering
You mean one of these............
http://www.bhphotovideo.com/c/product/355456-REG/Sennheiser_DC2_DC2_DC_Camera.html
Brian P. Reynolds is offline   Reply With Quote
Old November 20th, 2012, 05:09 PM   #3
Brian...thank you for your thoughtful response. That's getting closer, but what I was looking for is a cable that can use the Remote-Audio Battery Distribution System. The R-M BDS is a small "patch panel", that distributes power from an NP style battery.
J.
Old November 20th, 2012, 05:18 PM   #4
I'm in the same boat.. sort of.. but since the body-pack transmitter (or receiver) gets 10-12 hours out of rechargeables, it's not worth the cost IMHO. I use Sanyo Endloop and Rayovac Hybrid, both of which have very low self-discharge and will go 12 hr's w/o even shutting down for lunch.
The 9V(x2) Lectro receivers are another story.
Old November 20th, 2012, 05:52 PM   #5
J.
In the small box that fits into the battery compartment is the electronics to convert 12v down to the 3v that is needed by the TX / RX and note it has a flying lead on it to put any sort of connection on to suit the user.
A direct connection to the TX /RX with 12v without that converter will fry the electronics...... DON'T DO IT !!!!!
The cover plate just has a cutout in it to get the cable in.
Old November 21st, 2012, 05:40 AM   #6
Yes, you *have* to use the Sennheiser DC adaptor kit.
You then put a connector on the cable that fits your system.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply With Quote
Old November 21st, 2012, 05:33 PM   #7
Thank you gentlemen.
J.
Old November 24th, 2012, 01:34 AM   #8
I soldered a DC2 to the appropriate BDS cable to do this myself. It works, but there is a ground loop issue that causes a buzz when I connect the g3 to a usb-powered DR-05 recorder powered from the BDS4u. I've been troubleshooting this with Remote Audio and they say they have heard other reports of ground loop issues with the DC2s (which are mini DC/DC inverters that convert from my 12V to 3V).
I'm going to be doing a more exhaustive test later when I have the time to determine whether this problem also occurs when running the g3's into my 302 mixer and/or SD702 recorder which seem more immune to the DC2 ground loop buzz...
Tom Morrow is offline   Reply With Quote
Old November 25th, 2012, 11:53 AM   #9
Remote-Audio is a great resource! I had them make a custom cable for use with their BDS system to power my Marantz PMD-661. R-M is going to be my next stop for the SK 100 G3 power.
Tom Morrow - please keep the Forum up to speed on your progress. I've dealt with Stephen Reter at R-A, he's "Top-Shelf" as far as I'm concerned.
Thanks for the info!
J.
