Burning Directly to DVD at DVinfo.net
All Things Audio
Old August 20th, 2012, 12:09 PM   #1
Hi.
I am getting ready to tape several live events. I want to be able to burn a DVD directly from my camera as I tape and then use a DVD duplicator to make copies.
I was going to use a sony VRD-MC6 to burn as I tape.
Any better ideas as to how to do this?
I do have a Macbook pro that I could throw into the mix.
Thanks in advance for any help.
Brian
Brian Maynard is offline   Reply With Quote
Old August 20th, 2012, 01:56 PM   #2
Re: Burning Directly to DVD
Sure, why not. I use a pair of Sony DVD burners to make live DVDs. Beware that the start-up and shut-down times are significant, so they are difficult to use for short-form, fast-turnaround stuff.
No sure why this is in the Audio forum?
Richard Crowley is offline   Reply With Quote
Old August 20th, 2012, 02:08 PM   #3
Which camera do you plan to use?
In the past I have recorded to both a regular size DVD Recorder and a Sony Digital-8 recorder (similar to the mini unit you mentioned).
The key was the camera I was using had full manual control, XLR input connectors and audio metering, as well as a firewire DV output.
Using the DV (firewire, iLink) output connector from the camera to the DV input on both the recorders (during separate events) I was able to bypass the auto-level-only audio of the recorders and use the camera's full manual controls and metering.
You can still record using the analog outputs from your camera and/or audio mixer, but the recorder will be auto-audio-level only and there may be some audio/video sync problems.
If everything is combined in the camera first and then output DV firewire to DV firewire input on the recorder, those problems with audio are eliminated.
Jay Massengill is offline   Reply With Quote
Old August 31st, 2012, 02:19 PM   #4
I use an MC6 frequently. It's a pretty cost effective way to do it.
Mark L. Whalen is offline   Reply
