Zoom H1 with DSLR? - Page 2 at DVinfo.net
All Things Audio
Old June 21st, 2012, 10:56 AM   #16
Re: Zoom H1 with DSLR?
wait...magic lantern can't control agc on t3i? then why does it work on t2i?
Victor Nguyen is offline   Reply With Quote
Old June 21st, 2012, 06:58 PM   #17
You can turn off AGC without magic lantern on a t3i.. you just go in the menu and change audio to manual then set your levels.
I made a video a little while ago comparing on camera audio, an Azden shotgun straight into the cam, and the same Azden shotgun with a $10 headphone amp in the middle, and I've had what I would consider completely usable results with the headphone amp in there and using manual levels.
Don't judge me, I'm no pro haha! it's also out of focus a lot :\
http://youtu.be/v1DEd2PFL6k
if you skip to 4:40 you can hear the shotgun with the amp, with no editing done, I think it's pretty clean.
I also just started using a friends h4n, and the quality is awesome, but it's kinda bulky.
DSLR Photographer/Videographer from Massachusetts
Portfolio at http://ebourcier.com
Last edited by Evan Bourcier; June 21st, 2012 at 06:59 PM. Reason: Fixed video link.
Evan Bourcier is offline   Reply With Quote
Old June 21st, 2012, 09:32 PM   #18
In that test did you turn off AGC in the camera? Or were the results that clean because you had the amp?
Zachary Grimshaw is offline   Reply With Quote
Old June 21st, 2012, 09:38 PM   #19
Both. You run the amp and it boosts the signal into the camera, so you can turn off the ACG and run low manual levels, effectively bypassing most of the crappy internal preamp in the cam.
