Senn EW112-p G3 Buzzes at DVinfo.net
All Things Audio
Old February 23rd, 2012, 03:17 PM   #1
I am about to return a new Sennheiser EW112 (b) wireless system due to loud buzzing over the audio. Initially I determined the appropriate frequency version from the vendor site map, ordered and used auto setup. This is the standard lavalier model with body pack transmitter.
I have tried changing frequencies, adjusting the sensitivity and output level, replacing batteries and testing in different locations. Squelch eventually makes the noise go away along with the voice component. The only thing that stops the buzzing in the audio is muting the transmitter.
I have been using an older Sennheiser wireless for years and never had this.
Ideas or comments before it goes back?
Chip
*** http://www.vimeo.com/chipgallo ***
Chip Gallo is offline   Reply With Quote
Old February 23rd, 2012, 04:17 PM   #2
Re: Senn EW112-p G3 Buzzes
If you unplug the mic when its turned on does it still buzz? if it stops its the mic / cable (easy to replace) if it doesn't its the transmitter (and will need to go back)
Brian P. Reynolds is offline   Reply With Quote
Old February 23rd, 2012, 09:22 PM   #3
What a great tip, Brian. My old Senn mike fits and doesn't make the noise. Now B&H only has to replace the lav. Thanks for the assist!
