Yamaha MG166c Mixer. at DVinfo.net
All Things Audio
Old September 13th, 2011, 04:37 AM   #1
This appliance runs off mains power via a 18v 1.2amp cabled transformer pack which supplies via a proprietory plug in the back of the mixer. I have found nothing to indicate if the transformer output is 18vAC or 18vDC.
I am examining the possibility of running it off battery power. If the output is 18vAC, then there is a possibility that the mixer might happily operate on AB or V-Mount DC power of 12-14vDC.
Is anyone doing this.
Any advice will be greatly appreciated on whether the 12-14vDC power can be applied via the 18V socket through the internal rectifier which would be there if the input power is 18vAC.
Old September 13th, 2011, 05:23 AM   #2
Re: Yamaha MG166c Mixer.
Hi Bob I have the Yamaha MG 12/4 mixer and the psu has output AC17.5VX2 0.94A written on it so I would assume yours is of similar spec.
Hope this helps and not sure if you could run these off batteries, I tend to use the behringer 1002b if I need a battery mixer or the new twelco ones I have just bought.
Old September 13th, 2011, 07:25 AM   #3
According to Yamaha tech page it runs of 35VCT utilizing power supply PA-30 AC adapter.
http://www.yamahaproaudio.com/downlo..._datasheet.pdf
perhaps yours is different.
Good luck
Gerry Gallegos is offline   Reply With Quote
Old September 13th, 2011, 02:00 PM   #4
Thank you Gary and Gerry for your responses. I had been told a long time ago that I could apply DC of about 2/3 of the voltage to the AC input of another unrelated appliance and the the appliance would run as the DC would pass through the rectifier without harming things. If anyone has anything furthur your advice will be most welcome.
Old September 14th, 2011, 01:03 AM   #5
In theory, you might be able to connect a DC supply in place of the AC transformer. However, figuring out the correct DC voltage is a bit tricky.
To be safe, you'd really want to consult a schematic of the mixer's internal power circuitry.
For example, although the AC transformer is a center tapped type, you don't know whether it's really used internally with a center tapped configuration. It might be used in a dual-voltage configuration, with one of the transformer end windings connected to mixer ground (not the most common supply, but a possibility nevertheless).
If you don't have access to the schematic, or don't understand the various power supply configurations, you could easily get into trouble.
Greg Miller is offline   Reply
