#16 |
Re: XLR cable acting as antenna?
#17 | |
All Sennheiser mains receivers are balanced out on the XLR. The pocket receivers EK 2000, EK 3000 and EK 500 G2 are all balanced out - however, all EK 100 receivers are unbalanced.
John Willett - Sound-Link ProAudio and Circle Sound Services President: Fédération Internationale des Chasseurs de Sons |
#18 |
Interesting, I guess I've mis-understood some of the finer points of "balanced audio" for a long, long time...
It makes sense, now that I sit back and think of this for the first time in a zillion years, that any RF entering the cable would hit the input stage regardless of the nature of the signal being sent. Somehow in my basic audio classes a zillion years ago, I got this basic concept confused. Which shows that even old dogs (at least those who are willing) must allow their old tricks to be refined! Thanks.
Classroom editing instructor? Check out www.starteditingnow.com Turnkey editor training content including licensed training footage for classroom use. |
#19 |
Bill, don't fret, you were pretty close.
If the source signal is not balanced, then indeed that will unbalance the entire system. For example, if a wireless receiver has pin 2 hot, and pin 3 ground, then by grounding pin 3, the system will no longer be balanced (even if the input circuit is designed to be balanced), so the system will be more susceptible to noise pickup. However, if you disconnect the source, and leave the cable open, then the input can function as a balanced circuit, as designed. And yes, to take full advantage of a balanced circuit, the source should obviously have two pins which carry signals that are 180 degrees out of phase with each other (as you stated). But a balanced source only allows the system to remain balanced, it does not cause it to be balanced. Simple, in a confusing sort of way. ;-) (Just be glad you aren't dealing with RF, where some signal flows on the inside of the coax shield, and sometimes a different signal flows on the outside of the shield. I'm still having a hard time visualizing that.) |
