Zoom H4N recording fails / corrupt file : See Photo at DVinfo.net
All Things Audio
Old June 23rd, 2011, 02:11 PM   #1
Lately my H4N has created a corrupt file that is not recoverable. It has happened on two different SD cards made by Sandisk SDHC 2. A 4 and a 8 gig card. Anyone else encounter this issue? I always reformat the cards in the H4N before using and it's weird that it happens with about the 4th or 5th audio track I try to record.
http://i53.tinypic.com/2dkk0hi.png
Kelly Langerak is offline   Reply With Quote
Old June 23rd, 2011, 04:12 PM   #2
Re: Zoom H4N recording fails / corrupt file : See Photo
Never had this issue with the H4n. I also use Sandisk cards, 8 GB, and format them before each new project. Bad memory on the card? I don't know. Could be a strange coincidence with the placement of bad files, which creates the illusion of a pattern?
Andy Balla is offline   Reply With Quote
Old June 26th, 2011, 09:09 PM   #3
I've had it happen a couple times. In both cases it occurred when the batteries ran out during recording - apparently the data isn't actually written into the file until you hit stop, so anything that interrupts that could result in the file being corrupted like yours.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old June 26th, 2011, 10:38 PM   #4
I agree with Evan. A lot of unexpected things happen when the H4N runs low on power. Its unlikely to have 2 cards simultaneously go bad.
Pete Cofrancesco is offline   Reply
