Videomic into G3 transmitter at DVinfo.net
All Things Audio
Old May 28th, 2011, 08:06 PM   #1
I am saving up to buy a plugon transmitter and drum mic via Don Bloom's advice, but for now I would like to use my videomic a few inches in front of a speaker and send the signal to my h4n wirelessly via my g3 wireless system. Is there an adapter needed to block the battery power coming out of the g3 transmitter? Where can i purchase this? Would the videomic get me better sound than just dangling the senn. lav mic between the woofer and tweeter?
Eric Aumen is offline   Reply With Quote
Old May 30th, 2011, 07:12 AM   #2
Re: Videomic into G3 transmitter
Note that the tip and ring are connected together in the VideoMic's plug. This will result in the G3's line and mic inputs being shorted together if you plug the VM directly into the transmitter.
Old May 30th, 2011, 12:18 PM   #3
I ordered the cl-2 cable so I can hook into the dj board and get a line level feed. Does that sound right? Is there a way I can use the rode vxlr adaptor with the cl-2 if I want to run that wirelessly?
Old May 31st, 2011, 04:18 AM   #4
First - talk to the Rode distributor in your country. The Videomic. may include a blocking capacitor to stop the external power.
If it does not, you will need to have a blocking capacitor in the adaptor.
Talk to Rode.
John Willett - Sound-Link ProAudio and Circle Sound Services
President: Fédération Internationale des Chasseurs de Sons
John Willett is offline   Reply
