Beachtek XLR with my Sony FX7 how to?
Hey guys,
I have had issues in the past trying to use my Beachtek XLR DXA8 with my Sony FX7, noise problems etc. Can you please go through a basic run down on how i should install this on my FX7 to work correctly. See mine came with no instructions and i really want to play around with it. So a start to finish simple step system of what i should be doing would be great, can i just run it off the camera battery along with any equipment i have plugged into the XLR slots or do i need to use it with a battery aswell. I have very large camera batteries so this is no issue to suck there power down. You help is appreciated as always thank you. |
Re: Beachtek XLR with my Sony FX7 how to?
I have not used this device, but the Beachtek manual is online:
http://www.beachtek.com/pdf/DXA-8instructions.pdf |
#3 | ||
Here's the single most important piece of advice from the manual when using a BeachTek device:
"It can only be attributable to human error... This sort of thing has cropped up before, and it has always been due to human error." |
Ive owned the DXA-8, and it's just plain old noisy too. They discontinued it. It's passive, meaning you can't make your mic any louder than it is going in without a preamp. So you may as well try plugging your mic in directly to the camera.
My Work: http://www.youtube.com/ChadWork1 Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3, |
#5 |
I have the DXA-6 which is passive as far as mic gain is concerned but does supply phantom power.
I've never used the DXA-8, but the manual does indicate it's not passive but uses preamps. It's certainly possible those preamps aren't the greatest and could be noisy, but I know it's also easy to simply overpreamp when feeding a mic-level only camera input and that results in unneccessary noise. What specific models of mics are you trying to use? There are other points to check and test but for the moment tell us about your mics. |
#6 |
Yeah you get a little gain with the DXA-8, but it's discontinued.
#7 |
Discontinued or not, it's the one he has and asked about.
