What Is A Good Lav Lapel Mic For the Zoom, H1 at DVinfo.net
All Things Audio
Old February 17th, 2011, 10:47 PM   #1
I recently purchased a Zoom H1 to be used at weddings and events that I photograph. Can someone recommend a good Omni Lav Lapel mic that is technically compatible with the Z1.
Thanks for your help.
Bill Artman is offline   Reply With Quote
Old February 18th, 2011, 09:46 AM   #2
Equal Opportunity Offender
The Rode lavalier mic works with the H1, and I believe that this is also the case for their pin-mic product.
Andrew
Old February 18th, 2011, 10:46 AM   #3
Thanks Andrew!
Old June 24th, 2011, 08:21 AM   #4
Re: What Is A Good Lav Lapel Mic For the Zoom, H1
I have the same question but I want something like the VT-500 Voice Technologies or Sanken level of clean audio for lapel mics, but the connector doesn't fit securely. Can you splice in the correct pin connector for the H1 or would you recommend I go the opposite route with Lectrosonics 100 Series to be able to use a high quality mic?
I use my audio for weddings only and I'm wondering if Lectrosonics is better solution or can a high quality mic with the H1 be just fine?
If I get the Lectrosonics 100 Series - Wireless UHF Lavalier Microphone System then I would just stick with the mic it comes with??
Kelly Langerak is offline   Reply
