Zoom H4n - 1 XLR input to 2 tracks/control levels on tracks 3 & 4 independently? at DVinfo.net
All Things Audio
Old January 31st, 2011, 03:57 AM   #1
I'm just working through the operations of the H4n and have a couple of questions:
- In 4 channel mode, is it possible to record the input from XLR 1 onto tracks 3 & 4 simultaneously?
- In 4 channel mode, can the levels of tracks 3 & 4 be adjusted independendly of each other?
From what I can see, I'm pretty sure that the answer to both these questions is no, but it would be great if I'm missing something.
www.pfilm.co.uk
Mike Paterson is offline   Reply With Quote
Old February 1st, 2011, 04:51 AM   #2
why would you need a mono mic recorded onto two tracks? you can just pan track 3 to center in post... unless maybe you want one track at a lower gain for a safety track? hmmm... that would be a good idea!!!
in multitrack mode, input 1 can record to two tracks but will have only the one gain adjustment as it is only going through the one mic preamp... anyway, i think if safety is your purpose, the only option may be the on-board mics in 4 track mode at a lower gain, or using two externals, or both! you can 'unlink' input 1 and 2 and adjust the gain separately with the new firmware:
http://www.dvinfo.net/forum/all-thin...e-enables.html
Brian David Melnyk is offline   Reply With Quote
Old February 1st, 2011, 03:37 PM   #3
yes, that's exactly what I'd like to do - bracket record one mono input on tracks 3 and 4 at different levels for safety. I didn't know about the new firmware - thanks. That's something at least.
www.pfilm.co.uk
