Best $1,000 Shotgun?
I have up to a grand to spend on a mic and am interested in opinions. I have a Schoeps CMC641 with a CUT1 that I use for interiors and sometimes exteriors but I need an RF based exterior mic just in case I am in a high humidity situation and also for the extra reach on really wide shots. I am looking seriously at the Sennheiser 416. I am aware of the low frequency off axis issue and understand that I have to aim well when booming with it, which I can do. I have heard the comparisons with the NTG-3 and am also considering that, but I am leaning towards the 416 because I am a freelancer, the 416 has better creds and is practically indestructible. Are there any other RF based shotgun in that price range that I should be considering?
thanks, mike |
You might consider the Sanken line of mics. As far as "cred" goes, they are used extensively by NHK in Japan. Personally, my next shotgun will be the CS-3e
http://www.dvinfo.net/forum/all-thin...magic-mic.html There is also the CS-1 which has a single element and a wider pattern. The US Sanken rep said that it needs a less experienced operator. I might choose one for an on-cam, on-the-street, documentary mic. It costs $825 at a popular web store. The CS-2 was released after NAB, so I haven't tried it. $1,150. The CS-3e is a bit more cash at $1,415, but it's truly superb. I compared it back-to-back with the 416, though at different booths, through different amps, with different gains, and different headphones. Still, the way that the Sanken dealt with off-axis sounds was night and day compared to the Sennheiser. As I see it, the 416 is an excellent implementation of basic tube interference technology, but that technology is dated. The CS-3e uses three capsules and is able to achieve far superior off-axis performance. I'm not sure about ruggedness. Given that you have the Schoeps, you might never use your shotgun indoors or around off-axis reflections. if ruggedness is more important than off-axis quality, the Sennheiser might be the better choice. Maybe some others have extended experience with the ruggedness of the Sanken.
Jon Fairhurst |
Equal Opportunity Offender
Having the "right" mic won't instantly make you a great operator.
Stick with the NTG-3 so that: -- you don't miss any sound that otherwise sneaks off-axis -- the humidity won't stop you in your tracks (very embarrassing when the rest of the crew are ready) -- Rode have a pretty fabulous 10 year warranty, not that anything is likely to go wrong with the mic Heck, I would think that point #2 would easily seal the deal, given your humidity issues. Andrew |
DVCreators.Net
Budget in wind protection too...
#5 |
I have both of these for my NTG 3 and eventually a Neumann KMR81. Both mic's have similar diameters and the full windshield kit can extend its length to fit longer mic's. So far, I have used the Softie 95% of the time as it provides great wind protection. If you plan on only using a Rode, then their Blimp is cheaper than the full size Rycote.
Full Windshield Kit » Rycote Softie Windshield » Rycote |
#6 |
In regards to humidity, I have a Beyerdynamic MCE 86 /11 that doesn't like a moist environment.
Does anyone else have the same problem? |
#7 |
I like my Browning Citori 12 gauge.....oh wait....
Microphones! Street cred gained from having a Sennheiser? Ha ha ha! Yeah it's a great mic but get real...the result is all my clients have cared about for my 21 years in the biz! Kind of like the Neumann craze for VO's. Theres a LOT of other mics out there and some that blow the Neumann's away for less money! As others have mentioned, get an NTG3 to save a bunch of money. I am also a fan of the other mics mentioned. You can't go wrong with any of them. I have used the Sennheiser extensively and took a chance purchasing the Rode. Not once have I regretted the decision and not once has anyone asked what mic I used to make them sound so good! (sorry to come off a bit harsh but I was just in a similar argument over brands of shoes!!)
The older I get, the better I was! |
#8 |
DVCreators.Net
YouTube - Sennheiser MKH 416 vs. RODE NTG-3
Well there ya go. A $699 RODE NTG-3, which as you may have heard sounds similar to the $999 416, can be had with the essentials: full wind protection, an internally cabled K-TEK boompole - plus cables for the same $999 price. And you'll still have enough out of that $1000 for a $.99 taco ;) Actually use your 5% "dvinfo" coupon and buy 50 of them tacos. Check out the DVcreator Location Sound Package 4 at $999 |
#9 |
Guess I'm on a diet after getting the Sanken CS-3e. No Taco's for me. But I'm not complaining. It's the best mic I've used yet. I may be doing a comparison of the CS-3e to the Senn MKH 70 soon.
-Garrett |
#10 |
I forgot to mention that there is a great comparison of several shotguns on kenstone.net, which is why I like the Neumann so much.
As for the NTG 3, I have had a problem with suddenly loud sounds that cause a slight crackle whereas neither of my NTG 2's have this issue. Thus, for loud venues such as concerts, I use a NTG 2 when not wired into the sound board. |
