Looking for Sound Forge tutorials at DVinfo.net
All Things Audio
Old August 6th, 2005, 03:28 PM   #1
Capt. Quirk
Anybody know of any decent online tutorials? I'm particularly interested in how to select and reduce background noise. Thanks.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old August 6th, 2005, 06:57 PM   #2
http://www.vasst.com has lots of tutorials, including a Sound Forge Noise Reduction tutorial.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Old August 6th, 2005, 07:10 PM   #3
Capt. Quirk
Thanks Spot, that is what I was hoping for!
Old August 6th, 2005, 10:30 PM   #4
Capt. Quirk
I went to the tutorial, but all that shows is the title, by you, and some ads. No tutorial.
Old August 6th, 2005, 10:38 PM   #5
Capt. Quirk
Ohhhhh... Now I see that I need to join. Nevermind :)
Old August 7th, 2005, 08:16 AM   #6
Capt. Quirk
Spot- I'm using SF 4.5, and it doesn't have the "Capture Noiseprint" feature. Is there something else that will do the same thing?
Old August 7th, 2005, 08:55 AM   #7
Sponsor: VASST
No version of Sound Forge has "Capture Noiseprint". It's part of a separately purchasable plug-in called Sony Noise Reduction which should work with your copy of SF 4.5. If NR is too expensive, try BIAS Sound Soap 2. It's not as robust in function, but it's not as expensive either. Sound Soap 2 is pretty good for the money. I use it. Like any noise reduction, you need to remove less and make multiple passes to get good results.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old August 7th, 2005, 09:16 AM   #8
JR beat me to the answer. :-)
Sound Forge 7 and 8 now come bundled with NR from many dealers, so you might consider that an upgrade as it's basically free. But...there is no free solution to noise reduction that I'm aware of, other than the EQ method I talk about in that one tutorial there.
Old August 7th, 2005, 09:32 AM   #9
Capt. Quirk
John- Thanks for the tip about sound soap, I'll look into it.
Spot- Was the noise reduction for Vegas the only one, or did I miss another tutorial? I have been using the EQ method, but with little success. I think my biggest problem, aside from audio ignorance in general, was trying too aggressively to remove these unwanted noises. This of course didn't get all the noise, but did bring down the overall quality of the rest of the track.
