zoom H1 at DVinfo.net
All Things Audio
Old October 24th, 2010, 05:10 AM   #1
zoom H1
I can't seem to find anything technical that tells me about the functions of the H1 so I'm wondering if this is possible;
attach the H1 to a DSLR and use the line out to record straight to camera on 1 channel while recording with the H1 to the other channel.
I'm hoping I can record to camera, record to H1 & monitor audio - sounds too easy
anyone tried this with the H1???
Cheers - Paul M.
www.perbenyik.com
Old October 26th, 2010, 10:48 AM   #2
DVCreators.Net
Hi Paul,
I've read your question a couple of times and would like to help, however, I'm a bit confused. Could you re-phrase this one so we can help? I have an H1 and a 5DM2 so I can offer some assistance once I'm fully clear on what you would like to achieve.
The camera has 2 channels of audio. The Zoom H1 has 2 channels. Did you want to take the Line Out of the Zoom and put it's mixed output on 1 channel of the camera? If so, you can do this with a simple Y cable along with a Line to Mic attenuation cable. With the Y splitting the output of the Zoom H1, you would be able to monitor with headphones, and send the signal to the camera. I think this is what you want to do?
Guy Cochran
Old October 26th, 2010, 03:24 PM   #3
Are you talking about using the H1 built-in mics?
Or do you want an external mic to go to both the H1 and the DSLR? If that is the case you may want a mixer to send one channel to the camera and one to the H1.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old October 31st, 2010, 12:41 AM   #4
that's what I was after Guy - I hadn't thought of a Y cable - simple!!
Cheers - Paul M.
www.perbenyik.com
Paul Mailath is offline   Reply
