UCR 100 wiring for connection to mixer at DVinfo.net
All Things Audio
Old July 17th, 2010, 03:35 PM   #1
Any Lectro UCR 100 users in the group? I'm rewiring four receiver to mixer cables to use with a Sound Devices 442. I want to make sure I'm doing it the best way. Need to finish up this weekend. Your help is appreciated!
Bernie
Bernie Beaudry is offline   Reply With Quote
Old July 17th, 2010, 06:32 PM   #2
Mini-plug tip> XLR (M) pin-2
Mini-plug sleeve> XLR pin-1
Jump XLR pin-3 to pin-1
If using a TRS mini-plug, tie the ring and shield together. DO NOT wire it in a conventional TRS to XLR configuration.
The output jack is unbalanced, however it will pass the same signal to tip & ring of 'stereo' headphones.
Rick Reineke is offline   Reply
