What would you do? at DVinfo.net
All Things Audio
Old February 28th, 2010, 09:05 PM   #1
What would you do?
I've attached a clip of audio for you guys to analyze. Audio tweeking is my weakest link. Please have a listen and tell me what you guys would do with this track. BTW I'm working in FCP.
Brandon Carter is offline   Reply With Quote
Old February 28th, 2010, 09:11 PM   #2
No filter is going to remove that Texas accent (big grin!). Other than that, what's the problem? Sounds OK here..../Battle Vaughan
Old February 28th, 2010, 09:19 PM   #3
Sounds fine to me. What problem where you experiencing/having? I thought I heard some white noise in there but that could be my headphones that I have on(not mixing headphones).
Nicole
Nicole Hankerson is offline   Reply With Quote
Old February 28th, 2010, 09:34 PM   #4
Haha
No texas accent, LOUISIANA! HAHA
I thought it sounded pretty decent, just wanted some opinions on the sound quality. I thought it was pretty clean sounding but a touch nasally. A slight bit of echo but not bad. Im using a Senny G2 with Countryman B3.
Old March 1st, 2010, 12:48 PM   #5
Sounds fine. I don't hear noise and reflections as a problem.
I would EQ the LMs down a few dBs in post.
Old March 1st, 2010, 04:47 PM   #6
It's a little noisy. Not too bad. You can remove noise in Soundtrack Pro I believe. You select an area with just the noise, analyze it, then remove. Check the manual under noise.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old March 1st, 2010, 04:58 PM   #7
Sounds pretty clean, maybe a little too clean. I don't get any sense of the environment where we are. Lay in an ambience track low under it with sounds appropriate to the location ... rustling leaves, footfalls, a babbling brook, distant birds and insects, the buck moving through the brush. Not loud, just enough to give one a subtle sense of being there.
Steve House is offline   Reply
