Wind guard for studio microphone
I've taken a liking to using two microphones for my camera: one shotgun and the other a BLUE Dragonfly set at a lower recording level to capture peaks faithfully. I'm using a "dead cat" for the shotgun to guard against wind noise in outdoor recording. What would I use on something the size and shape of the BLUE?
chris, a quick google search turned this up: Blue | Dragonfly - Cardioid Condenser Mic | DRAGONFLY | B&H
Thanks, Trevor.........
But that wasn't really my point, whatever.
Rycote denies all knowledge, so does Rhode. Guess it's a "back to you" scenario, Gints - it's centre swivelled, which means just about any "ball" sock is going to have to be slit to fit. If no one has an off the cuff answer, you'll have to wing it. CS |
#5 | |
Assuming outdoor - from the picture it looks like the mount and elastic can be removed - so it should then fit inside a Rycote Basket Windshield or S-series.
John Willett - Sound-Link ProAudio and Circle Sound Services President: Fédération Internationale des Chasseurs de Sons |
#6 |
#7 |
These people make a very wide variety of foam and fur windscreen products for about all microphone brands and models...
Olsen Audio Group: WindTech Microphone Windscreen & Mic Muff Home Page |
#8 |
Blue Microphones
I'm using the microphone indoors without a wind guard of any kind. For outdoor use in windy conditions, I'd prefer to find a "dead cat" that will fit the BLUE Dragonfly microphone. Thanks for all of your suggestions, guys. Richard's suggestion for the Olson foam guards are probably the best I can do for now short of sewing my own Dead Cat from fake fur. Last edited by Gints Klimanis; January 4th, 2010 at 11:12 PM. |
#9 |
Since you are using it in a studio I think what you are really looking for is a "pop filter" (mesh disc on a holder/stand).
The mesh screen on your mic surrounds the mic element so you already have a wind/pop filter built in. Most sound guys remove any wind guards indoors so as to get the cleanest (least colored) sound possible.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/ |
#10 |
If you're after a "wind muff" sort of thing the folks at TheWindCutter.com, Professional Microphone Windscreens may be able to fit darn near any mic with something effective.
#11 | |
I still think it would fit in something like a Rycote S-series if you remove the supplied suspension.
#12 | |
#13 |
Thanks for the explanation, John. The BLUE dragonfly diaphragm is encased in a ball-shaped screen. Would that be enough? The S-series looks good and ball-shaped foams and muffs may also be suitable.
#14 |
The "ball shaped screen" is at best a popperstopper - for outside use you will really need a proper basket - check with Rycote to see if it will fit in an S-series, otherwise you would need a basket.
#15 |
Hi Gints,
Exactly what are you using the Blue mic for? On-camera interviews V/Os, music vocals. An unusual choice for interviews.. . I see it has nice sensitivity specs, that's always helpful for low-talkers. |
