#16 | |
Good news, Cousins! This week's chocolate ration is 15 grams! |
#17 |
Ok. I'll read it.
BTW, everybody says "buy a quality XLR cable" - but how can I recognize quality cable from low quality cable? |
#18 | |
#19 |
Cheap cable is stiff, has a memory - so kinks tend to stay in it and don't drop out. Mostly physical things. Cheap rubbish cable can sound good. After a few flexes, then poor solder joints can fail, or the actual plastic can crack. Some cheap brands are ok inside, but are not UV proof - and get harder as the sun attacks the plastic. Some types retain their flexibility in low temperatures. Some types have better screening - handy if you use them in electrical environments where interference can be a problem. I have never, ever heard a cable that makes the quality of sound better or worse. I have seen and heard plenty electrically fail, or physically fail. I've seen cheap connectors met when soldered, I've seen them squashed when somebody stands on them. Do mine have gold pins? They might have, I suspect I have some kicking around somewhere. Do the gold ones sound better - of course not!
I have my favourite brands, but this is just down to the fact they terminate quickly and simply and are tough and I can stand the cost. I like Neutrik connectors - we like them in Europe, but I'd be happy with Switchcraft too. The sound card mentioned in this topic is pretty typical - designed for output, not really input. You can always tell when the manufacturers web site has no specs for input - apart from mic/line - audio professionals and hobbyists use card where the actual input sensitivity is detailed. If you think about it, the average user of these cards has a headset for shouting at the on-line games players - so the mic level is probably expecting a very 'hot' signal - far more than you are giving it. If you are serious about recording then external devices are by far the way forward - although if you want internal, then maya cards are pretty good, and some have balanced audio and phantom power capability too. I've a Maya44e sitting in one machine, and an external Lexicon Omega on another - and these work really well. |
#20 |
Yeah, those SB cards are for the average consumer.
Lexicon makes a good product. Been using their products since the "Prime Time". (back in the dark ages) |
#21 |
Thanks for explanation!
#22 |
So far have been quite happy with the Lynx L-22 card.
#23 | |||
An external USB-connected audio device of some kind would probably be the least expensive way of getting decent audio quality. There are a variety of products available depending on your needs, budget, and what is available in your area. |
