sound in youtube really bad at DVinfo.net
All Things Audio
Old December 10th, 2009, 01:10 PM   #1
Hi everyone,
I use a canon XH A1s with a condenser mic.
Mix the lot in FCP6 , it still sounds fine, sometimes I adjust the levels a bit in soundpro , compress it in compressor, it still sounds fine. The moment youtube gets it it sounds really floppy en rough.
I use lowshlve filter and take out a lot of the low's but still it is brutal. I tried another mic, same. I ve set the audio to -12 db, switched on mic att. It all does not make a difference .
Anyone ???
Bas Paul is offline   Reply With Quote
Old December 10th, 2009, 02:08 PM   #2
Can we have a link to a sample?
Don Xaliman is offline   Reply With Quote
Old December 11th, 2009, 02:49 AM   #3
If it's fine before it hits youtube and not afterwards, surely it must be something with youtube, mustn't it - or with what you're giving it to them as?
Renton Maclachlan is offline   Reply With Quote
Old December 11th, 2009, 07:38 PM   #4
From Youtube handbook:
______________
Best Formats for Uploading
YouTube can accept almost any video format for upload, but for most users we have found the following settings give the best results.
■Video Format: H.264, MPEG-2 or MPEG-4 preferred
■Aspect Ratio: Native aspect ratio without letterboxing (examples: 4:3, 16:9)
■Resolution: 640x360 (16:9) or 480x360 (4:3) recommended
■Audio Format: MP3 or AAC preferred
■Frames per second: 30
■Maximum length: 10 minutes (we recommend 2-3 minutes)
■Maximum file size: 1 GB
_________________
Might be your audio file type or bitrate..... /Battle Vaughan
Old December 14th, 2009, 02:23 PM   #5
I compress to MPEG2 audio is in aac.
Here is a sample:
YouTube - Welcome to Yogatic!
