Does the Zoom H4n recharge ni-mh batteries with the power adapter? at DVinfo.net
All Things Audio
Old November 30th, 2009, 04:09 PM   #1
Hello folks,
I just received my h4n in the mail, I put some energizer 2500mah batteries in there and plugged in the power adapter, but after a while the battery bar hasn't moved a pinch. I know the instructions says it will not charge the batteries, however I have read else where on the internet by users that it will.
Does it work for you?
Sam Young is offline   Reply With Quote
Old November 30th, 2009, 07:25 PM   #2
No, it doesn't have this function.
Eric Darling is offline   Reply With Quote
Old November 30th, 2009, 07:33 PM   #3
Actually, it has been my experience that the H4n does recharge the batteries. Be sure to change the battery type from alkaline to ni-mh in the settings menu for it to work.
Nate Morse is offline   Reply With Quote
Old November 30th, 2009, 07:53 PM   #4
Who would have thought? Handy tip if it works.
Peter Damo is offline   Reply With Quote
Old November 30th, 2009, 08:00 PM   #5
I have switched it to the Nimh on the menu when I first tried to charge it, however it is still at one bar after two hours. Will charge it overnight to see what happens, maybe it is super duper super slow.
So charging does work for you Nate?
Thank you guys for the input.
Sam
Old November 30th, 2009, 10:33 PM   #6
I'll test it out again tonight, but I thought it did charge. Not sure how long it takes, though.
Old December 1st, 2009, 10:15 AM   #7
I left the unit plugged in overnight and my batteries went from zero bars to two. So, I think it does charge them. It just doesn't do a very good job. Fresh batteries from my charger showed three bars in the H4n.
Old December 1st, 2009, 09:41 PM   #8
Thanks Nate for the update, I appreciate it. I left mine overnight plus half a day and it is still at 1 bar. I guess it won't work for me! So your nimh isn't registered as full on the H4n even though it is supposed to be full from the charger?
Old December 2nd, 2009, 12:06 AM   #9
Fresh from the charger the batteries registered as full (three bars). But after turning it off for twenty minutes and then back on, I only saw two bars. I think the battery indicator might be a little off for nimh batteries because I rarely see them as full unless they came straight from the charger. Alkalines seem to register fine.
As for recharging using the H4n, did you have the unit turned on? I had it plugged in and turned on all night. I think the batteries came close to full charge but don't have any equipment to verify that for sure.
Old December 2nd, 2009, 07:32 AM   #10
Ahh, I left the unit off. I will turn the unit on and leave it charging. Thank you again Nate for the help, I greatly appreciate it!
Old December 2nd, 2009, 08:18 AM   #11
It is charging with the unit turned on! At two bars now, thank you Nate! Have a good one.
