Not sure about the ew100 G2 settings for the EX3 at DVinfo.net
All Things Audio
Old November 1st, 2009, 01:29 PM   #1
Sound level drops when using Senn ew100 G2
I have the EX3 and Senn K6/ME64 combo. I also have the Sennheiser ew100 G2 radio mic with the MKE 2-ew
I have the K6/ME64 plugged into channel 1 and ew100 into channel 2.
Could someone please tell me if this is correct?.
In normal recording I have the K6/ME64 recording into Channel 1, camera set to external, mic+48 and the cameras built in mic recording into channel 2, camera set to internal.
I just think, if theres a fault with one sound input, I have the other as a backup.
(perhaps this is wrong)
On the Edius timeline I then select the better sound channel, which is K6/ME64.
This seams to work OK for me.
I then sometimes use the ew100 G2 mic recording for the wedding vows for instance.
So what I do is, just flick the channel 2 setting from internal to external, set to Mic (under XLR input) and it then picks up my radio mic.
Is this correct or is there a better way.
Reason why I'm asking is, when my K6/ME64 is recording the sound into channel 1 and if the radio mic picks up a sound, say a groom speaking, the recorded sound level from the K6/ME64 drops.
I didn't think this should happen. So thats what makes me think I've a setting wrong somewhere, either in the camera or the radio mic.
Thanks in advance.
Last edited by Anthony McErlean; November 1st, 2009 at 06:20 PM. Reason: Update to post.
Anthony McErlean is offline   Reply With Quote
Old November 2nd, 2009, 07:27 AM   #2
I must have changed a setting in the ew100 G2 radio mic, this was causing the problem. I've reset transmitter and receiver and it appears to have fixed it.
