Stereo mic into iRiver ?? at DVinfo.net
All Things Audio
Old June 17th, 2005, 02:31 PM   #1
I just got a custom cable wired from a five-pin XLR (AT825) to hook into my iRiver (stereo mini). But it has a loud hiss in it. Cable guy thinks it is an issue with ground wiring. Does anyone have any experience with wiring stereo devices (or AT825) into the iRiver that can shed light on this problem? Does the iRIver need a non-standard miniplug wiring to work properly? I know monoplugs need to be wired backwards somehow.
Any other clues or ideas?
You are either growing or dying.
Bob Costa is offline   Reply With Quote
Old June 17th, 2005, 02:51 PM   #2
educated guess here-
a lot of devices like the i-river supply a small amount of voltage at the mini stereo mic input, to power the little consumer mics that most people use with them. it's kind of like baby phantom power. sometimes this can cause noise with mics that don't use this "plug in power."
Nate Ford is offline   Reply With Quote
Old June 18th, 2005, 01:21 AM   #3
For mono you need to feed the ring and NOT the tip and ground the sleeve
Do you know if the cable you have used the shield for ground and left the returns open?
Jack Smith is offline   Reply With Quote
Old June 18th, 2005, 05:26 AM   #4
Jack, I am trying to get a STEREO mic working, not mono. It has 1,3,5 grounded to the shield right now, but that gave me hiss.
Old June 18th, 2005, 10:39 AM   #5
Check out this link which describes the mics need for transformer
http://emusician.com/mics/emusic_audiotechnica_atst/
check out the last paragraph
