DXA-8 and a minidisc recorder at DVinfo.net
All Things Audio
Old June 13th, 2005, 01:39 PM   #1
Hello
I searched the forum and didnt find an answer. SO will the DXA-8 work with a minidisc recorder? Will there be grounding problems?
Jason
Jason Sanders is offline   Reply With Quote
Old June 13th, 2005, 02:24 PM   #2
I'll bet you'll be fine. The only problem I can think of would be the plug-in-power from the minidisc. I would assume the DX-8 has voltage blocking capaciters. The passive XLR adapter that we use has them anyway.
Marco Leavitt is offline   Reply With Quote
Old June 13th, 2005, 03:16 PM   #3
You should be fine, depending on how sensitive the MiniDisc input is. The DXA-8 doesn't put out line-level, just very hot mic-level signals.
As for grounding issues, that can happen with almost any combination of equipment. I don't think you'd be any worse off with this combo, and the DXA-8 has a two-position grounding switch. This should take care of most situations and should be checked anytime you use different mics or other components. Sometimes it's quieter to switch it, sometimes worse.
Jay Massengill is offline   Reply
