#16 | |
www.soundgeekproductions.com |
#17 | |
#18 |
So I have all the parts, and I wanted to post a few pictures of what I got going so far for those interested. I have a plan for the back cap, so I'll have to get back on that. At first glance, this fig 8 capsule is HEAVY... big bigger than I expected as well, but still workable and fits well inside the Rode Blimp. The suspension bands I used were the original ones the Rode comes with for the top set, and I went to the hardware store to get some others that were not as flexible on the bottoms.
At first I attempted to use the fig 8 without the capsule caps on which was a bad bad mistake. These caps are to eliminate some sort of interferance between the two capsules, without them you'll get a bad hum... possibly 60Hz. Working as intended though, they seem to sound rather nice and the bi-polar pattern seems very solid. I'm headed out now to go find some stuff to record at the nearby park and enjoy the nice day. http://soundgeekproductions.com/miscPics/012_MS_1.jpg http://soundgeekproductions.com/miscPics/012_MS_2.jpg http://soundgeekproductions.com/miscPics/012_MS_3.jpg http://soundgeekproductions.com/miscPics/012_MS_4.jpg
#19 |
Spent about 4 hours roaming around the park recording some birds near some large ponds. Ended up having my low cut on most of the time since the park is nested right in the middle of some major streets and a freeway, so you'll probably hear some of that. I recorded at 24/96k, edited some sections together fast, Sides are panned hard left and right, and converted to 192kbs mp3 for these examples. Also, my MK-012's are not modified........yet.
http://soundgeekproductions.com/miscPics/sfx/Ducks.mp3 http://soundgeekproductions.com/miscPics/sfx/Geese.mp3 http://soundgeekproductions.com/misc...mall_Creek.mp3
#20 |
Not bad, Zack. Seemed to me there was some HF hiss on the ducks track, while the geese track (maybe better SN ratio?) was quite clean (and sonically interesting, taken out of context). Maybe a little harsh in the mids, but I am always a proponent of active (but subtle) EQ in post on almost every signal, so that doesn't scream dealkiller to me. Spatial sense was pretty good, the best I think in the ducks track. For the price and the situation, not a bad combo I'd say, although the broadband ambient noise masks some subtleties, but the traffic's not your fault. ;-)
I forget, or can't find it in the thread, but what kind of capsule is on your MK012 for the middle signal? Cardioid, hyper, super? Also, do you might reporting what the fig 8 capsule ran you, price wise? |
#21 |
Ya I did notice the HF hiss when I was out, I'm hoping the mods I'll do later will help that out more, I got what I paid for :P . I ordered the fig 8 capsule from OktavaUSA direct for $350.00. Mid mic had regular cardioid (as you'll see in the pictures above a few posts), and no EQ was added post.
#22 |
Can't edit my previous post with the pictures, so here's what I finally ended up with for dealing with the 2nd cable. Having a nice dual cable was just too expensive, "ideal", but too expensive. This worked great as well, and even better with the fur over to help hold the cable snug.
I'm just going to tie off the two cables lower down the slack so they don't knock each other during a gust of wind or shifting. Pic 5
#23 |
Zack, great work and I didn't think you'd get those mics into the Blimp. Beaut pix too nice.
I'm not a fan of M/S indoors, too much chance for out of phase component for me. But I certainly appreciate what you're intending with your rig and I can imagine some great results especially if you lock onto some of these 3D films heading our way. Please keep us posted. Cheers.
Support your local movie theatre, they need it. |
#24 |
oh dear the Okatava Fig8 seems a really pretty bad or ill conceived design. And $350 + the cost of a body electronics is not that cheap IMO
The 2 diaphragms are VERY far from Coincident (that is they are not in same place) I'm guessing from the photo's at least 40mm apart, probably more like 50mm+, or 2inch. This will mean the resulting polar pattern will likely be totally & completely unlike a Fig8 above 1kHz. High end dual diaphragm mics like the AKG 414 which have their 2 diaphragms about 5-8mm apart start to "loose it" badly above 2kHz, this is compared to say a classic Ribbon mic or the Schoeps or Sennhieser designs that use a single diaphragm/ribbon to get the Bi-polar/ Cosign /Fig8 qualities. For what a 414 can do, see http://www.microphone-data.com/microphone.asp?mic=1239 As to how much this matters, depends on if you want "imaging accuracy" or stuff being in the right place. Or/if you like an interesting stereo "shimmer" effect of the "fundamental" & the harmonics of a given sound source being randomly panned and spread between the L&R speakers. I reckon a better option is:---- Ambient Products Emesser It's much smaller lighter, they have sorted the cabling aspects and it has a 15dB equivalent SPL rated at DIN/IEC noise Fig, so it's not at all hissy. Seems a bit expensive in the States, Eg $775 from B&H ATE 208 EMESSER MINI FIGR of 8 MIC SET - Compare Prices Mind you, I think this is the total package, mounting, cables etc, and is for sure way cheaper than the Schoeps or Sennhieser's that I use. BTW I have no financial or other connection with Ambient. John L |
#25 |
I hear what you're saying about quality and design, however 2 MK-012's + 1 Fig 8 capsule is still cheaper than the ATE (at least what I spent on them), and you're still one mic short for your Mid. This was my hole reasoning of going for the Oktava capsule instead of breaking the bank. Can you hear the difference between 40mm and 5mm spacing between capsules?.... I can't. However, I can hear the S/N difference, but that's something I'm willing to live with until I can afford what I really want.
Beggers can't be choosers, and I was definitely begging :P, thanks for the input John.... oh and I'm not an Oktava rep either :P just a typical consumer.
#26 | |
Fair enough Zack, I'm sure your set-up will produce some pretty dam good results. Hey you can get a pretty interesting result with a (totally pretend MS pair) a mic pointing at the sound source and any other mic as a pseudo S.
Agreed hiss is not a matter of opinion, it's just bad. John L |
#27 |
Another good SFX Test with the MS rig. I was shooting a film out in the Mojave Desert the last 2 weeks which the set consisted of a fully operational carnival. This is what I got standing under the Ferris Wheel. Originally recorded at 24/192k on a 702T with the listed Oktava MS rig in this thread.
Ferris Wheel
#28 |
Very cool!
#29 |
Sorry for the empty links above, I had to do some ftp clean up a while back and broke some links. I have since reposted all the pictures and sound examples at this link Oktava MK-012 M/S Config for those interested.
~Cheers
