Manual keyframing or Compressor filter?
What are the pros and cons of using a compressor filter in FCP to limit audio spikes? I have been keyframing to keep them down for broadcast (between -6and-4db) but it's getting tedious and I just heard about using this filter but I'm sure there is a drawback right?
"We are basically free, but who we think we are is not" Ram Dass |
I would definitely not try to keyframe everything. As you said it's very tedious... and a compressor can help you out a lot.
2- Which version of Final Cut are you using? This is a key piece of information. The older versions kinda suck audio-wise... but you can put the audio into Peak (which is on the FCP CD). FCP4 is decent. Ideally: Add a compressor filter with a soft knee/curve at the top. Typically these filters show you a picture and it will have a curve instead of an angle. They may be called dynamics instead of compressor. The soft knee sounds better. If you can't hear the difference it doesn't make a big difference though. At gentle amounts of compression it's not a big deal the quality of the compressor you use. To hear too much compression, push the ratio to 6:1 or higher, push the threshold really far down (i.e. -30dB), and push make-up gain up 20dB or so. Mess around with all these settings: Use a gentle ratio like 2:1 ~ 3:1 Threshold something like -12dB Attack and release something like... around 50ms ish. (This is a really rough figure) Make-up gain like 2dB (Sorry these numbers are going to be a little off) If you want to make the sound really loud while staying broadcast legal, then a higher quality compressor can help you do that... but from your post, it doesn't sound like you'd need one. A good article on compression: http://www.dv.com/dv_login.jhtml;jse...questid=180977 registration required. |
Thanks so much for your well thought response Glenn. I have FCPHD. I guess Peak is around my hard drive somewhere though I havn't used it. I'll try your advice and post back. Thanks.
